Question about Toshiba Refurbished SYSTEM BOARD 400CS SYSTEM BOARD Motherboard
Toshiba 400cs does not boot
I am running windows 95 on my 400cs. I powered it down and when I tried to start it later it would not. The ac power indicator light (green) and the battery light (amber) come on but when the on button is pushed the computer does not boot.
Any help appreciated.
cutsrock
Removed battery and plug in AC cord. Unit booted up and ran fine.
Posted on Apr 22, 2008
Toshiba satellite c660 stuck on windows splash
hi K Smith.
Here are some troubleshooting steps that may help in identifying the issue.
- Start by doing a hard reboot, remove the battery and unplug its AC adapter then press and hold the power button for 20 seconds and see if it will boot up.
- If these will not work remove the HDD then boot it up and see if it will still get stuck at the BIOS screen or not.
- If it doesn't get stuck on BIOS and boot onto a black screen that means it's the HDD that is faulty.
- If it does get stuck on BIOS even without the HDD that means it's the motherboard that is faulty.
- Last trick you can try is to remove the CMOS battery for a second then put it back in.
- If all these will not work you'll need to send it for a repair if its still under the factory warranty
or.
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then get it checked out.
or read up some more at this link.
Toshiba satellite c660 stuck on windows splash Google Search
Dec 08, 2017 | Toshiba Satellite A135-S4527 Notebook
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Toshiba Satellite L30/L35 starts to run then stops with a click sound then starts again. It does this over and over again.
The orange light means the battery is low.
Normally the clicking is the hdd trying to find its files and it will crash from time to time if faulty.
Replace the hdd.
Oct 07, 2017 | Toshiba Satellite Computers & Internet
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
I HAVE A GATEWAY 7320GZ.IT HAS ISSUES!!!!!!!!WHEN I TURN IT ON IT START 2 BOOT UP,BUT ABOUT 2 OR 3 SEC LATER THE POWER LIGHT STARTS 2 PLINK AND IT JUST POWERS DOWN ALL THE WAY.THIS IS WITH THE POWER CORD...
Hello, you can reset the battery, battery off, after 45 second push down the power botton for 5 secund and release,then put it back the battery and try turn on ,if don't working,you can try follow this link to change the battery.
Amazon com Gateway 7320gz Laptop Replacement AC Power Adapter Includes...
Jun 09, 2017 | Gateway 7320GZ Notebook
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Toshiba laptop reboots when on AC Power
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Jan 12, 2009 | ASUS G1S-A1 Notebook
Problem with Toshiba Laptop U
this is clearly a no boot issue. you can actually do a power cycle first. remove the battery and unplug the ac adapter. press and hold the power button on the computer for 10 secs to drain all power inside the computer. turn on the computer. if it still freezes, tried to boot to safe mode. as soon as you see the Toshiba logo on the screen, start tapping on the F8 button as quick as you can to access Windows Advanced Boot Options. then choose safe mode only. if it doesn't solve the problem then most likely, your Windows XP is already corrupted. try to do system recovery. please be reminded that you will lose all data if you run the recovery.
i hope this helps.
Sep 16, 2008 | Computers & Internet
Power down
Windows does not shut down. Additional information and causes that may cause Windows 95 or Windows 98 to freeze, hang or lockup when attempting to shut down the computer.
How to restart or shutdown the computer in DOS. If you are currently in DOS and need to turn off the computer press the power button. Note: some newer computers may not allow the computer to be shut down ...
Installing a pc computer power supply Write down important information from the top or bottom of the power supply such as the Model Number, Serial Number and specifications (such as voltage...).
Basic floppy disk drive troubleshooting Power down, unplug, and open computer, being aware of ESD and its potential dangers. Verify that the floppy connection is connected to the motherboard FDD .
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | Intel Motherboard
Computers & Internet Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
