Question about Kenneth Cole Womans Blue Textured Leather Watch
Screw I don't find my wacth in the file. My watch is square steel 27x28 milimeter the wrist watch slides into the slot. I looking for 4 screw. Help me please. If you want I have picture.
  • 831 Answers
You will have to contact Kenneth Cole.
1-800-KEN-COLE
Or find a local watch maker. Sometimes they have limited screws on hand but most likey you will need to contact KC. You will need the numbers on the back of the watch handy.
Posted on Jul 22, 2010
Quess rist wacth back removel
I have used a very small screw driver to open most watch backs. The main issue with doing this is that if you are not very careful there is a big chance you can scratch it. There normally is a slight gap somewhere between the back and the case of the watch. That is normally where I put the very small screw driver and pry it open. If you watch has a special seal or has a very nice finish on it you may not want to try it. Also I have not tried to open a watch like that so I don't know for sure if it will work in this case.
Aug 26, 2012 | Guess Jewelry W13523L2 4 Watch for Women
What if my small slide over the battery has come off completely? how do i put it back?
It should slide into/under a slot from the side, and be held in place by tension (not familiar with the exact model, so bear with me...). Some covers are held in place with a screw; you'll know this is the case if one end has a hole in it. Eyeglass screw kits are a good source for tiny screws. Hope this helps!
Sep 29, 2010 | Movado Museum Esperanza 604122 Wrist Watch
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    Watch not running
    The watch should start when the winder is returned home position.
    If pressing the winder does not cause the watch to start it could be that the winder may need to be screwed in (some watches include this as an additional feature to improve water resistance). Turn the winder to the right.
    The wacth should now start. if it still does not start, I suggest you find your nearest dealer in your area and speak to them about it.
    ( You can find your nearest dealer at http://www.tagheuer.com/tools/sitemap/index.lbl?lang=en ).
    Apr 08, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    How do you unlatch the battery of a timex ironman watch. I have the back open now
    You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
    Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
    How to adjust the wrist band
    Wish you would have posted the name brand but, look closely at the band you should find a small slot to slide out a pin that holds the links in. Or look at the buckle and move the spring pin to the correct location.
    r/
    David
    Oct 03, 2009 | Cartier Vintage/Antique Watch: #21,...
    Watch band resizing
    This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
    * I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
    Jun 27, 2009 | Lucien Piccard 26024 Wrist Watch
    For Casio F-91W how do I replace battery? I see 4
    Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
    May 11, 2009 | Casio F91W-1 Wrist Watch
    Shortening the Length of a Metal Wrist Band
    I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
    Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
    Rolex ss daytona
    www.rolex.com they should be able to help. Don
    Sep 19, 2007 | Rolex Daytona 116520 Wrist Watch
    Kenneth Cole Womans Blue Textured Leather Watch Logo
    78 people viewed this question
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
