Question about Nikon 80-200 2.8D Lens
Back focus at close distans - Nikon 80-200 2.8D Lens
TV SCREEN OUT
Back light or inverter/power supply failure
Oct 23, 2017 | Focus Televison & Video
I just received my Tomtom Go2535TM gps. There is no sound. What is wrong?
Take it back to the dealer for a replacement its faulty
Dec 24, 2014 | Tomtom GO GPS
How to reduce blur on close-up LEGO figure photographs?
Lenses have a limited 'closeness' at which they will focus. That is, unless it is a macro lens, you cannot focus closer than a yard or so (it is different for each lens). look on the barrel for markings or easier yet, move your camera back until the subject is in focus.
If you have to be back 3 feet - take the shots and then crop to make them appear larger.
Aug 15, 2014 | Cameras
What is gap setting for spark plugs on vw polo genesis 1043cc with cat converter petrol
the spark plugs must be change at 30 000 k/m if you use gasoline (octan 95) the gaps are already fix distan. 1.5mm . for new spark plugs , it will come up by use and consumptions , check the distan. for the metal on the meddle par must be 2.5 mm for new spark plugs by consumption it will go down to the meddle white cover.
Jul 19, 2011 | Volkswagen Polo Cars & Trucks
Hi i have a golf gti turbo w reg which in the wet the car is dangerous when you try to turn ie roundabouts the car looses control the back end spins out not due to speed i have to literally...
it may have miss aline rear cross member beside the brake rear need adjust ( one side more free)
or rear cross member bushing have damage , try compair cros two tie;s must be same distan.try complete turn right check right side tie distan. complete turn left check distan. compair
Jul 07, 2011 | Volkswagen GTI Cars & Trucks
My camera wont focus/ the lens wont close when i turn it off
i think its seen better days it will be cheeper to dump it and buy a new one sorry!
Oct 20, 2009 | Cameras
Ac starts blowing cold then in a short time quits blowing cold air
Hi! Volvo have some problems with compressor you must put in new distans chims so you get right distans between beltwheel and compressor.
Go to an AC work shop.
They could help you.
We have this problem on our S70.
BR
Tomas
Jul 13, 2009 | 1999 Volvo S70
Calbration
Recalibrate your SWR's. They can change if you swap from one Vehicle to another.
Aug 09, 2008 | Cobra 29 LTD CB Radio
OUT OF FOCUS
It appears your camera is in "macro" or "close-up" mode. The obvious solution is to take it out of that and back into normal mode. Since you didn't specify the make and model of your camera, I can't give you detailed instructions on how to do that.
Oct 18, 2007 | Leica Cameras
Nikon 80-200 2.8D Lens Logo
32 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
