Question about GE Heating & Cooling
I am looking for complete wiring schematics for a 1/4 HP Compressor Model BTB930A100A3
I have a smith+jones 1 Hp model 68288 what wire goes whair
look at side of motor it has a schematic for low and high voltage
Oct 16, 2014 | Pool & Spa
The regulator is leaking air and will not support the air tool I am using
They do not show the regulator as serviceable. It looks like you have to buy a complete new regulator. It is part #410028-E. You can find it on this link reference #42.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/MAC2400
Jul 13, 2011 | Makita Mac2400 212 Hp 42gallon Twin Air...
I HAVE AN INGERSOLL RAND SSR HP/40SE AIR COMPRESSOR W/INTELLISYS CONTROLLER 15-50 HP.IT HAS POWER,BUT DOES NOT HAVE ANY LED ON SCREEN.CHECKED CONTROL VOLTAGE-OK POWER LT ON,WHEN PUSH BUTTONS NOTHING...
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Mar 27, 2011 | Ingersoll Rand Stationary Air Cooled...
How do I wire it for 230
Cover plate on motor where wires come in often has schematic on back. Another place to look is for schematic on motor plate that shows specs.
Feb 23, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
I need the assembly instructions for an emglo airmate am77 1 1/2 hp air compressor head and valve assembly. please help!
there is aweb site called www.mastertoolrepair.com in the search type am77 should get schematic break down for your compressor, then go to internal parts and you should get a brek down and schematic on your compressor hope that helps
Oct 22, 2009 | Air Tools & Compressors
Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Aug 14, 2009 | Refrigerators
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Heating & Cooling Logo
134 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
