Question about Alpine Air XL-15 Air Purifier
Air Purification Unit Model ALP-615
The fan and the LCD screen seem to be working fine. It is the Ozone feature that does not seem to be working... Don't hear that little sizzle type sound and the smell is not coming out... We did notice the word "water" on the screen which we have never noticed before. The unit is no where near any water... Can anyone give any suggestions? This unit is only 2 months old and had been working great!'
THANK YOU!
Karen
ms_dixie_davis@yahoo.com
  • 3 Answers
Moist air reduces the efficiency of ozone production for this unit. I am not sure what the water thing is about.
Did you try cleaning the glass plate or ceramic plate ozone producing unit with soap free ammonia? Also did you try using a pencil eraser on the contact points on the glass plate? I think the ammonia cleaning and contact points on the glass plate should be your first option. Check your maintenance on the units manual.
Try the manufacturers website for their trouble shooting guide...walks you through most problems and how to fix them.
Posted on Jun 23, 2008
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
Can purifer work without the ozone card working
It will operate without a purification plate, as long as you are running in RCI mode or normal mode. If you normally run the purifier with some ozone output, then you will need a purification plate. Hope this helps you.
Feb 21, 2011 | Ecoquest Fresh Air Air Purifier
I just purchased a used XL15s. The unit when in manual mode emits an oder, but the air feels oxygenated. When you breath close to the machine the air seems to irritate or kinda burn my eyes. When in auto...
This is what the machine is designed to do! The machine emits a low amount of ozone, which is the purifier/sanitizer created by sunlight. Close to the machine, it's concentrated. When it spreads throughout the room, it kills odors and bacteria, and creates the fresh smell of clean air. The air truly is "oxygenated," because ozone is simply O3, instead of O2, and breaks down quickly.
If the numbered dial is set too high (try it at 300 to 500) it will smell "bleachy." Your "rule of thumb" is that when you've been away, and enter the home, you should experience the same fresh, clean smell that you get when you step outdoors on a bright spring or winter day.
When you're doing something that creates odors, like frying fish or cooking sauerkraut, turn the dial up to take care of that odor quickly, then turn it down for normal operation.
Leave it on the manual setting for continual purification. Often, the auto setting has been disabled, which might be the case in your older machine. (These machines can be 12-15 years old!) For an owners manual, go to www.vollara.com (new name of Ecoquest/Alpine). They may be able to help you.
Jan 17, 2011 | Alpine Air XL-15 Air Purifier
No my Breeze AT no longer gives me the Ozone smell.. what can be possible causes
Remove the purification plates and examine them for damage. If they are cracked, then they need to be replaced. Try cleaning the purfication plates with a solution of one part warm water and one part amonia. Take a old toothbrush and dip it into the amonia solution and scrub the metal grids on the purification plate. If there are deposits on the grids, scrub them until they shine and do both sides of the plate. Scrub the metal contacts that touch the plate as well. Rinse off the plate with tap water and allow it to dry completely for 24 hours or use a hair dryer to dry the plate.
Check the wiring that connects the purification plates for corrosion, that will often lead to problems.
Dec 06, 2010 | Ecoquest Breeze AT Living Air Purifier
We replaced the ozone plate and filter but our fresh air is not working. we are not getting the fresh air sent we did when it was new. any ideas?
Check the plate contacts and wiring. Make sure that the contacts are clean and make a good contact with the wiring. You can clean the contacts with a old toothbrush with some amonia and water solution. Make sure that the contacts themselves make contact with the metal grid on the purification plate. Hope this helps.
Oct 07, 2010 | Ecoquest Fresh Air Air Purifier
I have two that quit the ozone part. Just the fan works. I have a XL 15 and 880, that I can still smell just a little ozone. Can I fix these myself?
You might be able to fix them.
There a couple of things that can go wrong with these units, dirty plates, bad contacts, and bad reostat.
Dirty plates:
The ozone is generated by the purification plates. They should be cleaned once a month with a solution of one part amonia and one part tap water. Use a soft bristle brush like an old toothbrush and scrub the metal contacts on the plates with the amonia solution. Be sure to do both sides. Allow them to sit with the solution for 10 minutes, then rinse off with tap water and allow it to dry completely.
Bad Contacts:
There is a couple of metal strips that make contact with the purification plate. Check the contact strips and wires for corrosion. The metal strips can also be cleaned with the amonia solution as well.
Bad Reostat:
The reostat is the part that attaches to the control knob that sets the purification levels. Sometimes it can go bad. The easilest way to check them is to use a meter and verify that as the knob is turned that the resistance changes with the position of the knob.
Jul 16, 2010 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
429 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
