Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Taco shell burned on electric element and now the oven tries to get hot but wont get hot. what should I trouble shoot?
  • 112 Answers
A taco shell wont hurt a element.....some elements are easy to remove..take it out then reinsert a few time s if this fails take the element to a store an get a replacement.
Posted on Jul 20, 2010
I get a start? when pressing start and oven wont come on my whirlpool electric oven
Terrence, Could be defective oven element, control board, etc. have a good tech. diagnose and estimate repair. Check the attached links trouble shooting,instruction and guides for electric oven, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool Oven Won Turn on
Troubleshooting Guide for Whirlpool Electric Range
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jul 29, 2016 | Whirlpool Ovens
Any trouble shooting tips. My heating element under the rollers is not working
The heating element may have burned out - do you know anyone who can test it?
It may possibly also have a thermal fuse inside - that's not something you can easily replace, but it's cheaper to have someone replace that then to have them replace the heating element.
Jul 31, 2014 | Nostalgia Electrics Hdc 701 Carnival Hot...
The bottom oven is heating up very slow.
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
Jan 23, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven temp
I am experiencing the exact same problem. May try to trouble shoot myself if no one provides assistance on this site. It looks like the problem has to do with either the Sensor, Heating Element or etc..
Jul 03, 2010 | Amana ACF4215 Electric Kitchen Range
I have Super capacity ultrabake system electric won't turn off.
I had this with my oven, it just kept getting hotter and hotter. Had to replace the whole control panel. Mine was a Kenmore but I suspect they are similar.
Apr 10, 2010 | KitchenAid KERC607 Electric Kitchen Range
I have an Ariston electric oven that seems to get too hot & burns
You can try going to a lower wattage element. EX: Our oven can take a 2500 - 5500 watage element. The lower the wattage, it won't heat up as fast/hot.Plus it saves on your power bill over time. Go to the Ariston website, or find your element number and check the web for a lower wattage.
Jan 26, 2010 | Ovens
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven heats very slow
get a multimeter and test the resistance of the element and ohms, be sure to turn off the power first, take the element loose, and ohm it out, and check the resistance of the element. Most multimeters have a continuity setting, and try that and see if the element has continuity. if it doesnt, chances are that that is your bad element
Jan 23, 2009 | GE JTP20 Electric Single Oven
Just not workin
maybe a loosing wire. move the stove , disconect power and take the cover and look for a loosing wire at the bake element or a burning bake element
Apr 22, 2008 | Kenmore 96213 Electric Kitchen Range
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
61 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
