Question about RCA RT2360 System
No sound everything is hooked up properly, all switches are set correctly, but still no sound. have 2 blinking red lights on speaker display on monitor.
  • Anonymous May 31, 2008
    I HAVE THE SAME PROBLEM.... EVERYTHING WAS WORKING FINE, THEN QUIT. I HAVE THE TWO TOP LIGHTS BLINKING ON THE DISPLAY WITH NO VOLUME OUTPUT AT ANY OF THE SPEAKERS. I HAVE DISCONNECTED, INSPECTED, AND RECONNECTED ALL WIRES. EVERYTHING LOOKS FINE, BUT STILL NO OUTPUT.... HAS THE SYSTEM COMPLETELY DIED, OR IS THERE A FIX SOLUTION ? WOULD APPRECIATE ANY HELP OR SUGGESTIONS SOLVING THIS PROBLEM.
  • amoroso80 Feb 23, 2009
    That doesn't help much. specially when you are not a tech savy. What can I press, touch, unplugg, etc so I can fix this problem? "speaker impedences"? where can I find the control for that? can I put it up above 4 0hm?
    Thanks!
    Sergeant:
    Champion:
  • 319 Answers
Blinking LEDs indicate a problem with outputs. Or speaker impedences are too low (below 4 Ohm)
Posted on Apr 22, 2008
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
No sound
Try the other inputs and see if you have the same problem with them. That will let you know if the problem is the tuner or if it is something else.
Since your receiver does not shut off after a few seconds it should not have an amplifier problem. If it did shut off quickly it is know as the protect mode and normally indicates that you have a blown channel, not always, but normally it is that.
If you get no audio from any function, you may have a digital board problem which is a very difficult problem to isolate and repair.
A couple of things you can do to make sure it is not something like a wrong setting is to make sure that the "Tape Monitor" switch has not been pressed accidentally. If the "Tape Monitor" is engaged it wil appear that everything is normal with the display and functions, but you get no audio from anything unless you are recording on a tape. This can happen even with no tape deck connected to the unit. Study the display closely and see if "monitor" or "tape monitor" is lit up anywhere in the display, or if you have an led on the tape monitor or monitor switch, that led could also be lit up red. If you turn the volume up all the way, do you get a very faint amount of audio? If so, you probably do have the tape monitor engaged.
Also check that the speakers are activated. If you have only one set of front speakers you want to make sure that only those speakers are activated. You will have a button for speakers "A" and "B". Make sure that only speakers "A" are turned on. Some receivers will not have any output if you have both "A" and "B" turned on but only have speakers connected to the "A" speakers.
If your receiver has a button for the headphones make sure that is not engaged as well. Many receivers will not have output to the speakers if the headphones are turned on. Or if you have headphones connected, try unplugging them.
Those the only user type of things that you can do unless you have some good electronics troubleshooting skills and the proper tools. So if you have checked those things and still have no audio you need to take it in for service.
Here is a link that you can get your owners manual from online for free. It is always a good idea to study the owners manual to make sure you have everything connected properly and have the settings correct as well. Just go to this link and put in your model number exactly as it is on the front of the receiver to make sure you get the right manual. If you put in the wrong model number you will get no results when you search for it.
http://books.jvcservice.com/
I hopes this helps, and if so a "FixYa" rating would be appreciated.
Dave
Aug 16, 2008 | JVC RX-6000V Receiver
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
May 05, 2008 | Computers & Internet
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Apr 27, 2008 | Yamaha DSPE390 Amplifier
No sound from monitor speakers
The monitor must plug into the PC as the external speakers did.
Apr 16, 2008 | Westinghouse L1928NV Monitor
RCA RT2360 System Logo
403 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
