Question about Hardware & Accessories
How to reset the programming on timex lamp timer TX12694TA
I have tried reprogramming the timer multiple times but the programming i put in the first time will not change. Is there a way to reset the timer and start all over?
For some Timex timers, press PROG and MODE at same time to reset timer.
Open following link for random Timex manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Posted on Mar 31, 2011
How do I charge timex digital timer 12/874
Copy following link to identify timer and download possible manual:
2) Usually you plug timer into outlet for 1/2 hour to charge internal non-replaceable battery. Other timers have replaceable battery. Always reset timer before programming. If timer display does not show with charged, or new, battery, then try timer on different outlet, and/or replace timer.
3) If timer does not show on link above, add comment and include photo or clear description of timer.
Dec 05, 2012 | Timex EASY TO SET TIMER BY TIMEX
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
I set the time on and time off. has worked before . doesnt work now.
I do not have repair for defective timer.
Most timers have limited 1 year warranty, except some Intermatic timers that have limited lifetime warranty.
Last step troubleshoot for timer is to reset and reprogram.
Timex Easy set is reset by pushing down Hour and Minute button same time.
If functionality is not restored, then buy another timer.
If timers fail frequently, then test outlet with circuit analyzer. And read load rating, try timer on different load, for example high wattage loads will shorten life of timer, and not all timers are made to control every type of load. Buy appliance timer for air conditioner or toaster oven.
Aug 14, 2011 | Timex EASY TO SET TIMER BY TIMEX
I have a model #Te111(TX12677T), I am having a problem with programming this Timex light timer. I can get the time on, however when I try to program each day it will not hold it's memory. Help ...
Open following link to identify timer and download manual:
If the manual does not match product, then add a comment with clear description of timer and what you have done so far to set timer so I can see problem clearly.
If timer will not hold programming, then try resetting timer if it has a reset button.
If timer has battery, remove battery and replace with new battery, and try resetting timer in that manner.
If functionality is not restored, then move timer to different outlet and connect to different lamp.
And always test outlet with cheap circuit analyzer from home center.
Outlets that are out of code can affect electronics including timers.
If outlet checks out, then timer is probably defective.
Most timers have 1 year limited warranty.
Intermatic DT620 has limited lifetime warranty and might be better value long-term
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Woods 59377 is nice timer sold under different brand names at Lowes, Target, on-line:
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU/ref=pd_sim_dbs_k_1
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Jul 26, 2011 | Hardware & Accessories
Timex Model # TE111 (TX12694TA) Needed: Directions for setting. amooney47@yahoo.com
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 06, 2011 | Timex Watches
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
Lost our instructions for TE111 - can you email them?
Timex TE111 must be 24 hour indoor lamp timer.
Instructions say plug in and wait for 30 minutes.
This indicates that timer has rechargeable battery.
If battery won't charge, then timer is no good
Two internet links say Timex TE111 is TX12694TA
Here is link pdf manual
Here is another link
Another link to fixya from 2 years ago gives written instructions
Oct 05, 2010 | Timex Hardware & Accessories
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
Oct 02, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Need instructions for a Timex Timer Moder #TE111 (TX12694TA)
To set the timehold down the TIM button until Day flashes, Use +/- to adjust then hold down time until hour flashes..Repeat until set.
To program,
1. hold down prog until the cursor starts to flash at 12:00
2. Press PROG to advance to the day or day group you want to program.
3. press + to advance the cursor to the desired ON time
4. press mode until display reads "on"
5. use the + to move the cursor to the desired ON duration? Clock shows this also.
6. press mode until "off" is displayed. then advance the cursor thru the period the outlet should be off. (stupid to have to do this!)
7. press MODE to select as the ON or OFF period(!)
8. press TIME to exit programming.
9. Press PROG again to program another set of days.
Stupid system.
Good luck.
Dave
Nov 23, 2008 | Hardware & Accessories
Hardware & Accessories Logo
249 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
