Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
My Frigidaire Professional series dishwasher will randomly display a PF (power failure) code. It doesn't do this all the time, only occasionally. Is there an override or a way to tell how "done" the dishes are or to continue the cycle?
  • Frigidaire Master
  • 43,501 Answers
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Posted on Mar 07, 2011
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
My Frigidaire Gallery dishwasher will run initially when i oporate it on a normal cycle. The time will start to lower then, it will go back to 90 minutes and then shut off and then a PF code will appear. ...
Hi Gabriel, thank you for allowing me to assist you. PF is commonly referred to a power failure and you should be able to start a cycle. Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it. I hope this information proves to be helpful in a small way.
Aug 05, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I have pf code on the display already changed the control board same code as befor
heatman101
Feb 05, 2011 | Frigidaire Professional Series 24 in....
My frigidaire dishwasher is blinking lights and a
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
The PF(power failure code) comes on several times
heatman101
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
May 27, 2009 | Frigidaire Dishwashers
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
1,000 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
