Question about Maytag Neptune MAH6500A Front Load Washer
Maytag neptune washer 9 min
Seems to run good through all cycles till 9 minutes then goes to 7minutes try to pump then back to 9 minutes. what to do. thanks
  • 487 Answers
Check your pump for obstructions, including the filter
Posted on Apr 22, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
Jun 29, 2005
More results from
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytage neptune
"nd" refers to a No Drain issue .check for restriction in pump, restricted drain hose loose wire at pump, bad pump.
The pump had a suds lock. Unplug the machine for a minute. Plug it back in and run a cycle on hot to get rid of the excess soap.
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
My maytag digital whasher machine stops when is ready to spin
My mah6700aww would get to 9 minutes then stop, water would not evacuate. I took the exhaust pump/motor apart and found a piece of plastic (foreign debris) in the impeller; remove the obstruction and re-installed the pump/motor; problem solved. Three bolts that hold the pump/motor in place are 12mm. Also, important to mark the top of the plastic female electrical power connection since it is possible to reverse the connection. I saved $350 min. if you do need to replace the pump/motor they cost about $150 at an appliance parts store.
Good luck,
Dec 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer won't stop running/or shut off after cycle
clean the small presser hose out and check the pump sump make shur there is no obstruction
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
203 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
