Question about Pelican XBOX Desert Camo Controller (PreOrder ) (XBPEDECACOP)
Desert storm 2 game controller
When i play game my mouse and keyboard device not working.so please find the solution and tell my thanks
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
I have been having an issue where my mouse becomes very slow and jumpy when playing black ops. At all other times it is fine. Any ideas what could be causing this.
Do you experience lag while playing the game? If the game lags, mouse movement will probably lag as well. Do you have another mouse/trackpad/input device you can try? If your other input devices work, it could be a problem with your mouse.
Check to see that you have the latest drivers for your mouse. It could be that obsolete drivers are causing the problem.
May 12, 2011 | Microsoft Wireless Desktop 3000 Keyboard
I cant acess my conflict desert storm game which i have installed it shows disc not entered
For gamecube? What do you mean installed, you shouldn't have to install anything on a gamecube.
Mar 25, 2011 | Gotham Games Conflict Desert Storm II for...
My problem is the conflict desert storm game i have downloaded from cd orginal but when i play it it shows no disc entered
Uhh.....downloaded? Dude, you have to install that, and you need to have the physical disc in the computer while playing.
Mar 25, 2011 | Video Game Consoles & Games
Logitech Profiler does not detect my logitech dual action gamepad, why? I have a computer that uses vista 64bit.
Hi, Please uninstall any LGPS version present on your OS - Then please proceed to clean boot. -> Unplug any USB devices connected to the computer ( Less keyboard + mouse ) If you have a corded keyboard + mouse please use it rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software, plug the hardware when needed. -> Should work.
If a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If the problem persist, swap computer and try, if it does not solve then contact customer service for replacement
Thanks and have a nice day Julien
Apr 16, 2010 | Logitech Dual Action for Pc (963292-0403:)...
Video is lagging while playing games.
If you using onboard graphics them i could be a problem of shared memory, you can alter this in the bios
kind regards and please don't forget to rate us
Dec 13, 2008 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Games are not working Properly, Video is lagging
try putting nvidia 9800 video card, that shoud solve your problem.. and check the game requirements if it runs on 512 or 1gig.. tnx tell me if goes well..
Keyboards additional buttons not working
you have a couple of options here 1st try this go to start then my computer and right click on my computer then go to properties than look for device manager scroll down to where it says keyboards and open it right click on the one one showing your keyboard and look for remove and click on it it will ask you if you want to remove it from your system press y after it is done you will have to restart the computer once the computr is loaded there will be a found new hardware pop up on the taskbar and it will tell you about the keyboard let this finish loading and it will tell you that your device is ready to use or it will tell you that there was a problem and it may not work properly hopefully this works if not please please let me know and i will give you the other options ok best regards mike
Aug 09, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Keyboard and mouse
There are no games currently support mouse and keyboard. The only future release that has been announced so far that apparently does have it as an option is Unreal Tournament 3. I suspect that you won't see many games that support it though.
Oct 21, 2007 | Sony Playstation 3 (PS3) Console
About play station 2
The device to use PS2 controllers (or any game controller) on a PC is called a superjoy. http://www.goldenshop.com.hk/AI-trad/pc/pc_joybox4.htm
Sep 22, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
Top Pelican Video Game Consoles & Games Experts
James Wishart
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
