Question about Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 Does not Power on
I purchased an Insignia IS-LCDTV32 back on Aug. 21, 2005. Unfortunately, last night my tv would not power on. I called Insignia Tech Support and they told me the same BS story; unplug it and plug it back in. As other postings stated, it did not work. It seems to be a power supply issue, but I am no expert in electronics. I really do not want to deal with Best Buy. Does anyone no of a reputable company in the Aventura, FL (North Miami Beach) area? Any suggestions would be greatly appreciated.
Note: If I replace the power supply, would that solve the problem? Or would it be more cost effective to replace components of the power supply.
Thanks!
    President:
  • 2,712 Answers
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try this..if you unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $20 or so), or just change the faulty capacitors. You can make out which are faulty, because their caps will be swollen on top. Here's a pic
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 35V. however, if you dont find 35V, you could use a 50V as well. They will be slightly larger, but you should be able to get them to fit in.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each depending on the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 27, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
Tv will not turn on
Look for any loose contacts in the power cord. Wear protective gloves, shake the power cord when the TV is on, and find out whether it is getting on/off. If not, the problem lies inside, like dry solder and/or leaky/dry capacitors.
Aug 07, 2012 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 Intermit picture and sound
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Some TV is very prone to bad solder.
Feb 27, 2008 | Insignia IS-LCDTV32 32 in. Television
Lcd got hit by lighting
Hi
There is internal fuses in the power supply but this would mean removing the back of your tv, They would need to be replaced with the same ampage ect.... so read the fuse carefully.
Having said this i would be suprised if thats all it was considering it was struck by lightning, but you may be lucky
Check your power supply first for any obvious signs of damage if it is fried then take the part number of the board and Google or Ebay for a replacement.
Hope this helps
Apr 07, 2010 | Insignia IS-LCDTV32 32 in. Television
I have an insignia 37" lcd. the power will come on but i have no picture or sound and i can't shut it back off without unplugging it
Unfortunately your TV will require service. You may call 1-888-237-8289 to arrange for a technician to visit your home.
Oct 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Sep 17, 2009 | Insignia IS-LCDTV32 32 in. Television
There is no picture, it worked fine last night
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Insignia IS-LCDTV32 32 in. Television
My Insignia NS-LCD32 TV won't power on. The remote has good batteries, the outlet has power etc. Insignia says to unplug it it for a few seconds and then plug it back in. I tried that multiple times w
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
Jun 03, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia TV is only showing 1/2 picture
You are having problems with component failure. This could be a simple problem of over expanded solder connections that have expanded beyond the contact points on the board. This is reffered to as cold or broken solder joints. The other problem amy be actual component failure, such as bad capacitors or semi-conductor components. The unit need to serviced. You can call the Best Buy customer support telephone line at 1888-237-8289 and give them the model number of your television and the problem you are having. They should be able to give you a evalution and esimate of the repair costs. I hope this information helps you with your problem.
May 09, 2009 | Insignia IS-LCDTV32 32 in. Television
No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Apr 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Parts for Insignia IS-LCDTV32
Click here to find the power supply for your TV. Keep in mind that these power supplies boards are pulls from used LCDs.
Good Luck.
Aug 22, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
234 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
