Question about Sharp LC52SB57UN LCD TV
Sharp lc52sb57u - Loss of Controls
Have a sharp lc52sb57u. While using the set the volume all of a sudden races up to 60 (max) and I have NO use of the remote or side panel controls, except for the power button. Any ideas of the cause or how to fix? I have tried unplugging the set, which works sometimes, yet the problem persists and comes back. I have tried removing the remote from the area, which has no effect.
likha
  • 790 Answers
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Posted on Oct 09, 2007
  • 6 Answers
SOURCE: Sharp Aquos turns itself off
My LC37D6U had this problem, thought that I was going **** at first, came to find out that there was a firmware issue with the system. I got ahold of the updates for my particular system and just applied them. ** issues turning on and off now, just the sound going dead after 18 months.
Posted on Mar 09, 2008
SOURCE: volume issue
I have the same problem. When I adjusted the volume on the cable box, it was solved. Turn up the volume on the cable box, and when you use your remote, it's super loud, even at midway!
Posted on May 20, 2008
  • 50 Answers
SOURCE: remote does not work for Sharp lc42d85u
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug unit from back of unit
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug unit from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
If you get to step 7 and the remote still does not work then you need to replace the ir sensor board (aka) LED unit per Sharp.
if needed here is the orignal part info DUNTKE868FM01 about $12.00+ tax
Posted on Mar 18, 2009
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
How do i connect my sonance 275 SE amplifier to my denon receiver
The answer depends on if you have external speaker level volume controls (usually in-wall type) between the amp and the speakers.
If yes, hook the RCA cables from the 275 inputs to the Denon's Tape Output. With speaker level volume controls set to max, use the level controls on the front of the 275 to set max level desired in each room.
If no, then you must use a line level volume control between the Tape Output and the 275.
Jun 22, 2013 | Sonance Audio Players & Recorders
GA867WJSA
If the audio level is set so by the company, you can't cheange it.
Apr 23, 2012 | Sharp Televison & Video
What are the frequencies that the bass and treble controls on a Yamaha AX-396 amplifier control? I recorded alot of music direct from the amp to my pc with the bass and treble controls at max and need to...
The bass and treble controls (as well as volume) have no effect on the recorded output if you're using the traditional jacks a tape deck would use. Only PRE-OUTS get massaged by sound controls.
Even if you DID affect the recorded signals, WHY are you using such exaggerated settings? Or was it by mistake?
In theory, passing the modified output back through the same controls (set to Minimum this time) would undo most of the unwanted effect. Assuming their precise and mirror image for gain and loss.
Aug 23, 2011 | Yamaha AX-396 Amplifier
I have a sharp 32" bought at Walmarts at the Christmas before last and the low volume is driving me nuts. In my small living room with Volume set at 60 it still is not loud. Is there a trick to get louder...
Unfortunately it seems to be a sharp thing. I have a sharp 46 inch and there are times when I find it difficult to hear. Some channels seem to work fine with the volume right around 20 - 25. Seems to be quite often though that my volume is set over 40 and still struggling to hear. Seems with my tv that there is no difference between it being set on 35 and 60. They sound the same. Surround sound is the way to go if you stick with sharp.
Jul 10, 2010 | Sharp LC-26D6U 26 in. LCD Television
My volume only goes up to 60 and Ican't get it to go any higher-what do I do?
That's all it is, it goes from 0 to 60 and no more. Check volume settings on the cable box or sat receiver if you are using one.
Dec 02, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Continued question on Skewed picture and loss of control functions.
Not all the time but yes I have seen it happen about 60% of the time with the DMD board going bad. But it is possible that the DMD board is not the only problem your TV is having. The digital board (another board in your tv) can cause both these problems at the same time too. It is something that needs to be troubleshooted. But this info will narrow it down for you.
Mar 27, 2008 | Samsung HLN4365W 43" Rear Projection...
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume issue
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
Dec 29, 2007 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC52SB57UN LCD TV Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
