Question about Akai LCT3201TD 32 in. LCD Television
Television will not turn on
My television with combined dvd will not turn on when you first you hit the power the green light comes on and then the red light turns on and no power
  • 758 Answers
You can contact the manufacturer to see if your device is still under warranty so they can replace it for you
Just follow the link below and it will redirect you to their website
http://www.akai.com/contact.asp
I hope that helps
Thank you
Computerrep
Posted on Apr 22, 2008
  • 3,037 Answers
To further help this problem I need to know if the lights are flashing and whether you hear any noises, does it sound like the tv is trying to start up?
Also did anything happen that might have caused this problem?
Thanks, As soon as I get a response and as many details as possible, I can further diagnose the problem. Please give me as much info as possible.
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    I am thinking the board went bad right now, many of these tvs have had board problems within 2 years of purchase
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 3,422 Answers
HI,
It can be a power supply issue.You will have to get this repaired by a tech or if it is under warranty just replace ti.
Goodluck..
  • Priya darshan Apr 22, 2008
    do the hard reset first by unplugging all the cords for 4 hours and then plugging it back in.
    If no result, check the line cord and make sure you are getting power
    into the set. A bad line cord is quite frequent too..
I need the three digit code for the ge universal remote control for sylvania 6513DD please.
Hi, You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Nov 06, 2010 | Sylvania 6513DD 13 in. TV/DVD Combo
Our RCA52 wont turn on. The green light comes on
Replace the CP150, CP120 and CP114 capacitors. You can get that repair kit from www.tvrepairworld.com whicj also contains the instructions.
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Turns on then off
Replace bulb and clean dust from cooling fans.
Apr 20, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Got hit by lighting spike blows fuses when plugged in
The television has problems in the power supply board. The high transient voltages in the spike may have damaged all the board in the unit. This is because of the speed in which it occurs. The Power supply has other safety blow out components in it to stop this damage. If you are lucky the components saved the rest of you television and just blew out the power supply. You will need to have the television tested and see if this is the case. The customer service telephone number is 1-800-631-3811. Give them the model number of you television and ask them for a location of the nearest service center. Call them and ask them how much they charge for estimating repairs for you type of television. They should be able to help you. I hope this information helps you with your problem.
Apr 29, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
No power
Set is going into protect, major problem. Unplug, get Pro repair around $250.00
Apr 08, 2009 | Hyundai ImageQuest HQL320WR 32 in....
Tv will not turn on, makes clicking noise as the green light blin
clicking = power supply not coming up
bad power supply, or bad (shorted) part causing power supply to not come up
with a volt meter we can troubleshoot
Feb 05, 2009 | Akai LCT2715 27 in. LCD Television
The power supply is defective on this TV.
There seems to be a very high failure rate on the power supplies after about 18 to 24 months.
Apr 22, 2008 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3201TD 32 in. LCD Television Logo
23 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
