I replaced the hotroller on a panasonic workio dp 2030, after setting the fuser unit inplace the machine turns on for a minute then shuts off, it doesnt boot or power cycle. What could have caused this?? a pinch in the wire, continuity. please assist thanks
  • yan dikshteyn Jul 20, 2010
    i removed the fuser and still the same and the n the drum it wont fully boot to the main screen it will for a few seconds the screen appears then goes off, and doesnt fully boot the machine so if the fuser is out its not the fuser??
  • 2,359 Answers
The thermostat/senor is disconnected or damaged.
Within inches from the heat roller there is a senor that look like a diode or resistor. (see picture) .
the shape will be different but the function is the same. This diode/resistor show the temp of the roller.
If the resistance is out of range then the fax will not power on.
Do a good cleaning job and look for fragment on broken diode/resistor.
Use contact clean to clean all contacts and resit the roller.
Posted on Jul 20, 2010
How do i fix it?
possibly all of your ink has dried out and is worthless .
Aug 18, 2015 | Panasonic WORKiO DP-6030 All-In-One Laser...
And what do we do for the E04-02 Erreur machine on Panasonic DP 4520... when after service hour - rush...
The code can be reset in service mode, LBP fuser reset.
E04-02 indicates a jamming problem in the fuser unit, usually accordion jams. Correct the fuser problem prior to resetting the code.
Mar 05, 2011 | Panasonic Workio DP-3520 Copier
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Getting error j43 on workio 190, but there is no paper jam
yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Feb 08, 2010 | Panasonic Workio DP-190 Multifunction...
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Panasonic workio 3000 error code E04-01
Your FUSER is not warming up. It needs to be replaced.
Jun 29, 2009 | Panasonic WORKiO DP-3000E Printer
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
Fuser web
PM is preventive Maintenance - It's kind of like changing your oil! you need to have certain expendables replaced such as Fuser. There should be a P/M kit you can order for this that will include everything.
May 23, 2008 | Panasonic Workio DP-2330 Printer
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
Panasonic workio dp-4530
the power switch going off is a saftey function because when the cover is open the AC line inside the machine is open circuit.
When you close the door you effectivly close the circuit however if the machine still detects an open circuit the machine trips the power switch as a safty precaution.
Possable causes...
FAULTY DOOR INTERLOCK
FUSER UNIT lamps/fuses
Thank You
Feb 15, 2008 | Panasonic Workio DP-4530 Copier
59 people viewed this question
jasbo
jasbo
