All of this sudden my pictures are write protected. i need to fix this now!
  • 396 Answers
Assuming you are using Microsoft Windows the pictures could have been directly copied from a CD which will be Read-Only Files. You must have the picture files on rewritable media such as a memory stick or hard drive.
1) Right click on the file icon.
2) Select properties.
3) Under the general tab, you will see Read-Only and Hidden check boxes. 4) Uncheck the Read-Only and click OK to save the property changes.
Hint: you can select multiple files by using the Shift Click or Ctrl+ Click then Right Mouse Click to change properties.
Posted on Jul 20, 2010
    Brigadier General:
  • 10,406 Answers
Right-mouse click on a picture, and click Properties.
Near the bottom, remove the check-mark before 'read-only'.
Flat screen TV suddenly no picture or sound
This is a protection error indication and might need attention by a qualified service technician.
Aug 13, 2012 | Televison & Video
My camera notifies protected card any time i inset a card in it. the card did read before but now it has suddenly started to be rejected by the camera.i don't know what to do now.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 30, 2011 | BenQ Cameras
My unit ht x20 suddenly Stop and shows "PROTECTION" can anybody help?
The protection indication is triggered by an Amplifier output failure. This is done to protect your speaker system. You will need professional help to fix it because it involves stripping the receiver , removing the faulty component, getting replacement and re soldering that component back.
Aug 08, 2011 | Audio Players & Recorders
My Nikon coolpix S710 has suddenly come up with 'Memory card is write protected and wont take pictures now. Does anyone know how to fix it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 18, 2010 | Nikon COOLPIX S710 Digital Camera
SD card suddenly says write protected; wasn't before - how do I fix?
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Jun 18, 2010 | SanDisk Sansa e140 MP3 Player
I have a Maxell 8 gb, S880102A. which suddenly
Here's how I fixed it:
open Regedit and navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrrentControlSet\Control\StroageDevicePolicies
If there is a WriteProtect key (REG_DWORD) then
1 = Write Protect On
0 = Write Protect Off
Mar 08, 2010 | Electronics - Others
Hi..
Suddenly the card you have inserted is locked so that's why is says write protected. To unlocked the it get or remove your card from your camera. You can see in your memory card there is a small button her try to slide the button to unlocked. Insert your memory card back to your camera and try to take a picture it will take a picture.
Thanks for using fixya
Regards
PCmania
Sep 03, 2009 | Nikon COOLPIX L5 Digital Camera
Card protect message doesn't allow any activity with camera how to remove?
Hi there
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 25, 2009 | Toshiba PDR-4300 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
