Question about Philips HTS3450 System
The equipment began buzzing after powering on. The buzz begins high then slows down to a crawl and then stops; audio works fine after that. We started switching it to an unused audio source instead of powering it off, which worked for a while. Now it does the buzzing whenever we switch between sources, too.
  • Anonymous Jul 05, 2008
    After powering began buzzing
I had same thing happening until it finally died all together. no sound at all.....everything else works.....and sub lights up in standby. i took sub apart today....and found that 2 capacitors had swelled. you can see where i guess they got hot...because of the glue type stuff surrounding them went from yellow to browish -burnt color. so i'm looking for 2 capacitors before i can tell you if its the problem.
Posted on Jul 07, 2008
  • tjsfowler Jul 07, 2008
    i replaced the two 470uF 25V capacitors in the subwoofer..........with 470uF 35V ones......cause they where all i could find around town....and my sound is back:) the 35V ones are bit bigger but they fit into place for me. hope this helps out someone out there:)
    Sergeant:
    Champion:
  • 319 Answers
Sounds like a problem in the unit's power supply, have it checked by pro-tech
Posted on Apr 22, 2008
Why does my headset buzz all the time even when I am charging
If it is a constant low-pitched buzzing it is probably mains hum which can be difficult to eliminate.
There are two sorts of mains hum; conducted and radiated. Mains operated audio equipment suffers from this when the power supply smoothing is ineffective or when a hum loop has been inadvertently created. High gain preamplifiers with non-shorting inputs, high impedance peripherals and long leads make equipment more vulnerable.
Even battery powered equipment with a high gain can suffer from mains hum received like low frequency radio waves radiated from nearby mains operated equipment and supply wiring.
Oct 17, 2016 | Radio Communications
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
My laptop speaker won't stop buzzing. It began
A buzzing/humm sound could be a earth loop problem. This is caused by connecting amp equipment into different mains power outlets.
Use a power board and connect all your amps and laptop to the one power board.
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Speaker buzzing at random
It sounds like the socket on your computer is becoming worn or has a loose solder joint.
If you feel comfortable with a fine tipped soldering iron and stripping your computer down I would take a look there first.
Also check the power supply for the speakers to make sure it is not getting too hot.
Sep 09, 2009 | Logitech Z-2300 Computer Speakers
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Kac-8401 buzzing noise
If the buzz is real high pich the faster you go and lowers to a low pich when you slow down then it is you alternator on your engin.
The only way to stop this is to go to an caraudio store and buy a noise filter which will stop the noise. The only bad thing about getting an noise filter is that it will cause the watts on your amp to go down a little bit because the noise filter runs your power source through a box with a step up transformer and a step down transformer. I hope i helped you with your problem
Jan 25, 2008 | Kenwood KAC-8401 Car Audio Amplifier
Audio fuzzy or cuts out
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Nov 26, 2007 | RCA HD61LPW165 61" Projection HDTV
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Gopali
Apr 23, 2007 | JVC AV-30W475 30" TV
Philips HTS3450 System Logo
128 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
