Question about Canon EOS 450D Digital Camera
Tamron lens error code 01canon eos 450d
Tamron lens error code 01 when trying to shoot in manual mode error message saying clean lens sensors
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 19, 2010
  • gestall Feb 27, 2011
    Excellent, the placing it on a flat surface and letting the camera be pushed up by the lens worked and remedied my error code 01. Mnay thanks
  • Andrea Lock
    Andrea Lock Feb 27, 2011
    Thanks so much for giving me feedback, it helps me improve the solution. Please feel free to rate the solution.
  • 94 Answers
Either lens diapharm unit is faulty.
or camera contact mount assy unit is faluty you check connection flex is not come inside camera from main pcb.
Posted on Aug 08, 2010
Error code 001 with canon 450d
Seems a lot of people are having the same problem. Take the lens off the camera and clean the little gold contacts (metal squares) on both the lens and the body with isopropyl alcohol or pre-moistened len wipes.
Mar 21, 2013 | Canon EOS 450D Digital Camera
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
EOS 450D/18-55 IS, problems with AF Hi all. I am using a Canon EOS 450D, 2 years, with standard 18-55 IS lens kit. Yeasterday a friend shoot a lot of fotos indoor, with the incorp flash, once outside I...
I had a similar focus problem with a Tamron 70-300 for canon. What can i tell you is that if you o not have experience in this domain you should NOT disassemble the lens because you will have a very hard time to put it back together. Also, it's very hard to allign all the glass lens inside and you may end up in making it worse.
As I see this, you have 2 options:
Either you learn using the camera in Manual Focus mode, which is not a bad idea, in time you cn become faster than the AF :)
or
you can try to find a shop that sells cameras, they may direct you to a service, it does not have to be canon but must be a person with a technical background in cameras and such.
Regards,
katharsys_i
Mar 06, 2011 | Canon EOS 450D Digital Camera with 18-55...
Hi, I have a canon eos rebel xs. the mirror is kind a dirty, can it be cleaned by me or need to have it cleaned at canon service centers?s I also have a Tamron Telephoto lens, when I do a full zoom in...
This is a digital camera and I suspect it's not the mirror that's showing dirt it's the sensor. If you are seeing small bits of dirt on your pictures then it's dirt on the sensor. I would suggest having it cleaned at a camera store or repair facility if you are not comfortable with doing it yourself. Cleaned improperly can damage the sensor and renter the camera pretty well useless. The dirt inside the Tamron lens I would also suggest cleaning and if you are getting an error message you may as well send the camera in for a complete cleaning. There are kits on the marked to clean the sensors but again if you are not confident that you can do this then sent it to people that can and do it on a regular bases.
Sep 25, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Error 01 tamron lens 70-300 mm af 4-5.6 with canon dslr 450d
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 28, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Canon EOS 450d not clicking on AF mode
this may have to do with the lens rather than the camera, try swapping the lens with another one and see if the same problem happens in AF mode with the new, borrowed lens, also remove lens and check that the gold connector between the two are clean carefully wipe with a dry q tip but be careful not to allow dirt to fall into camera body.
Apr 12, 2010 | Canon EOS 450D Digital Camera
I've just purchased a Sigma 70-300 F4-5.6 lens for a Canon EOS 450D. When I take a picture I get an error message ERR 01 Communication between Camera & Lens is Faulty Clean the Len Contacts. To take...
It is asking you to clean the electronic points on the lens that come into contact with the camera body when the two are fitted together, in order to power the lens functions.
If other lens work ok, try giving the lens electronic contact point on the mounting plate a light rub with a dry cotton-bud, may be a fingerprint .
Oct 14, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Problem with sigma 70 300mm dl
If the lens is a super it may need a rechip
Aug 19, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Canon EOS 450D  Digital Camera Logo
1,148 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
