Question about Samsung Computers & Internet
Only the blue coloured objects are seen perfect while other objects lose the colour. the problem persists for few minutes but then suddenly all colours appear fine .Plz give me a solution.thnx
    President:
  • 2,571 Answers
If all the cables are correctly attached, sounds like your monitor is failing.
I have had a few monitores do this, usually give them a little tap, they come back on for a while, but its usually a sign to be looking for a new monitor, unless its under warantee
Posted on Jul 20, 2010
Why are my goldfish loosing their colour
Is you problem related to the fault to your TV?
Jul 23, 2013 | Televison & Video
Faulty picture which corrects itself after a few minutes.
Due to persistent on/off some components inside the TV might have become faulty, leaky. It can also be due to lose contacts. This might need attention by a qualified service technician.
Jul 24, 2012 | Televison & Video
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Bad ghosting of all colours
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Color shift problem with 330GS
This is because the RGB filters in the camera are not perfect, and there is no one "green" colour. The green pixels pick up a wide band of colours, and are somewhat sensitive even to red and blue, especially near where green shades into red.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
