Question about Amana AER5845QAS Electric Kitchen Range
There is an F14 error code when I plug the range into the outlet, then the clock comes on. The oven light and convection fan work, but the top elements and the oven don't heat up.
  • 15,935 Answers
F14 is a memory corruption on the Clock Module.
Replacing the module is your only fix.
It appears your Clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
Bake and Convection preheat abort after a few minutes
Hey Jeff Bassler,
How about... Instead of such an expensive experiment
You have a look at some related scenarios cited on
applaincepartspros... My concern is not getting fault codes.
Sorry:
I would need to know your service HISTORY...
SPECIFICALLY: Did this unit ever work?
(to disregard the notion of a FACTORY wiring error)
((proper trouble shooting = ASSUME NOTHING)).
Convection Q&A
http://www.appliancepartspros.com/whirlpool-relay-brd-sheild-12001694-ap4010046.html#qa1
Also see support video (page bottom - same URL)...
Jul 12, 2017 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Oct 07, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Dec 21, 2007 | Kitchen Ranges
GE JES1290,
Not sure about an F14 error, but an F4 error is a shorted (or even just greasy) temperature sensor (thermistor). That could cause trouble with the convection and fan, etc. like you describe.
It looks like the thermistor on this model comes as part of the heater or one of the covers, etc.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find a very good exploded view of it at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00058700/00058754.p01.pdf
You can find parts here: http://www.geappliances.com/shop/prts/
Nov 11, 2007 | GE JES1290 Convection/Microwave Oven
Amana AER5845QAS Electric Kitchen Range Logo
484 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
