I have a Sony model KV 36HS500 it takes awhile to come on sometimes and the LED blinks 5 times when it is on
  • John Ryan
    John Ryan Jul 20, 2010
    I will try that now thank you
  • 10,594 Answers
5 times LED blink error code is related with picture tube performance and error name is incorrect white balance.
This problem can be fixed easily if you are familiar with electronics stuff repair.
Take off back cover of tv and adjust/ increase Screen volts by rotating control knob that is located on flyback transformer.
This adjustment will fix your tv problem.
Let me know if you have additional question.
Thanks.
Posted on Jul 20, 2010
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sometimes does not come on can hear it Degawser
bad connection inside . soldering must be done again .
Sep 11, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY KV-36HS500 will not turn on. Stand-by mode blinks 6 times then repeats. Repair man checked out our phone system earlier today for signal loss and put 500 V generator on phone line to house to check...
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Aug 12, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega trimitron tv stand by timer is flashing
Check to see if the blinks are in a pattern should blink X number of times pause and repeat sometimes more than 1 sequence will appear. this link has a list of blink codes and what they mean.
the tv dude
Jun 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony tv
Something is Wrong with the Video.Check Video out,Q705,732,761 and other components on the C board,c also check Q218,219,220 on the A board.In addition,unit could be in IK blanking,try turning up Screen Slightly
Nov 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby mode and can't get tv to work
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Thanks,
Dan
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Nov 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
