Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Just after removing the vacuum...i clean the filter...then turn pump only on and it wont work..it worked good while vacuuming...cleaned the plates..still nothing...HELP
  • mark Gianotto Jul 21, 2010
    no power or just no sucksion
  • horky Jul 21, 2010
    no power..it is pluged in..let it cool down thinking that may be the problem..over 24 hours now and still wont work..no power
  • 297 Answers
Well this may be a stupid thought but make sure the outlet works other items. Never know maybe the breaker tripped.
If it is actually the pump itself, intex will replace it for free for the first 2 years.
you need a valid receipt then call them they will e-mail a claim sheet fill it out and fax it back they will have a new pump to your door within days
Posted on Jul 21, 2010
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Nov 30, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
No pressure on gauge on filter pump
The same thing happened to me. So frustrating! I guess the pump that comes with the intex pool is not strong enough to do this. At least that is what I was told. So I just ended up sending that vaccum back and getting a catfish vaccum. Works great!
Jul 29, 2014 | INTEX Sand Filter Pump
I can run my dc17 to clean my floors but when I put it upright to use the wand it turns off
I called Dyson and they walked me thru the process of making sure nothing was blocking the airflow and suction. Everything seemed fine (not blocked). We couldn't figure out anything on the phone and I was still having the same problem.
Trying to figure out the solution, I removed (entirely) the filter that you're supposed to clean every 6 months and ran the vacuum (I cleaned this filter 2 months ago). It worked! I cleaned the filter (again!) and let the vacuum run and it seemed fine.
I can understand why they won't instruct you to completely remove the filter but it would save a lot of time if they just had you check ALL the options.
I hope this helps!
Longmont Epoxy Garage Floors
Sep 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush will not spin. filters are clean, no clogs, belt is fine. remove canister, it works fine plenty of suction.
Probably a good idea to remove the brush and clean as best you can. Add some WD40 at each end by the plastic clips and turn by hand until they move freely. Reassemble being sure the belt is on properly.
Oct 12, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
NO SUCTION ON FLOOR
Dear Thyagie,since you said the cleaning tool attachment is working,I guess that means the cleaning tool attachment still has suction" so theirs a good chance that there is a clog that needs to be cleared and you wont need a new vacuum at this time.
But you will need to try and trace the clog and clear it. I would start with the tube by the roller brush and work my way up from there !
Also check the roller brush and the belt and make sure it's working properly.If your vacuum has a filter make sure it is clean,and of course make sure the vacuum bag is not full.
I hope this helps,EarlsOK
Dec 09, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
120 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
