Question about HP w2207 Monitor
The monitor automatically displays the menu that switches between different display settings and keeps iterating through them indefintely. Only does it when hooked up to the computer. I have two identical monitors and this problem occurs with one monitor only, the other one works fine when hooked to the same computer.
    Brigadier General:
  • 10,406 Answers
It seems like a hardware problem inside the monitor.
What's cheaper -- paying a qualified technician to try to trouble-shoot, or buying a new monitor, and responsibly recycling the old monitor?
Posted on Jul 20, 2010
Apple multi scan 20 display. Screen works fine but green is predominant. How and where do I adjust the green intensity?
This can be adjusted by the RGB settings on the menu (monitor setting menu button on the monitor), Brightness color contrast also helps.
That is providing that its the settings thats causing your problem. In my experience the VGA cable sometimes shorts out producing that green hue. You may need to shake the cable a bait to see if it clears up or causes weird iterations. Once this happens it means the cable is shorting. It could be a broken solder to a broken wire. Replacing the vga cable and resoldering the connectors inside the monitor (where the cable jack connects to the main board) fix's the problem.
Feb 25, 2010 | Apple Multiple Scan 20 20" CRT Monitor
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
As soon as I login the menu display gets activated automatically
if you dont know what caused this ... restore the system to an earlier date ...one when ya are sure that the problem wasn't present ..
Oct 03, 2009 | Acer AC713 17" CRT Monitor
Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Jun 24, 2009 | Compaq TFT8020 (White) 18" LCD Monitor
The display menu keeps flashing and i can't get rid of it.
Bad control chip, mine has the same problem. If under warranty - send it in. I just tossed mine and bought a different LCD.
Nov 08, 2008 | Samsung SyncMaster 720N Monitor
Usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Nov 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
HP w2207 Monitor Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
