Question about Electrolux EOU6330 Electric Double Oven
Main oven switches itself off - Electrolux EOU6330 Electric Double Oven
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Sounds like cooling fan not working. check the fan and a limpet stat that switches it on. without the cooling fan the oven cabinet overheats and a safety cuts out the oven.safety stat could be faulty if no prob with other stuff.
Posted on Jul 20, 2010
Oven turns it self on and off
you need to put it back on manaul setting it sounds like you have the timer on auto
Nov 21, 2011 | Hotpoint Ovens
I have changed the element on a neff u1661 main oven but still doesn't heat up. I noticed that one cable is loose possibly the earth?.the top oven and light and clock all work. Any suggestions please.
Is the loose cable on the element , if yes ISOLATE THE APPLIANCE BEFORE REMOVING PANELS
Usually they are spade terminals remove the affending connection, with a pair of pliers carefully press the terminal into itself, not too hard, it will be hard to put back on the element, move the terminal from side to side and ease on with continuous pressure. while you have the back off if you have a multimeter switch the mains back on, use extreme caution select A/C voltage above 250 volts, switch on the oven the fan will start to blow measure across the terminals, if you get a reading of 230 volts A/c the element should start to heat up. If no voltage, send me a reply.
Hope this has been helpful
John
May 19, 2011 | Neff U1661 Double circotherm super...
Main oven bulb changed now new one will not go out.
There is probably a problem with the oven switch. If you are careful, you can, after switching off the mains, remove the oven light switch, pull off the live terminal and insulate it. The turn on the oven mains again and see if the light still comes on. If it does, there is wiring problem. If it does not, the switch is faulty and needs to be replaced.
Feb 05, 2011 | AEG D5701-4 Electric Double Oven
Oven not workiing
If it is a double oven, then there will not be a plug fitted to it.
It should be hard wired directly into a main 30 amp switch box
If there is no power at all, then it could be a faulty main switch unit, or
the fault could be at oven connector block.
You really need a meter to check for power, both at the switch box and the oven itself.
Another possibility is a fault with the timer unit on the oven itself.
Apr 05, 2010 | Neff U1421 Double circotherm Electric Oven
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
Oven switches on and off itself while cooking,
The element in the main oven switches on and off as it reaches the correct temp, this is supposed to happen, however, if you mean the oven is going off altogether, then I would suspect that it is overheating, and the safety stat is cutting the oven off.
Check to see if the top cooling fan is working o/k. because if it is not, then this will cause the prob.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Maytag CWE 4800 oven bake element
Go to google and type in model and IOM and it should give you what you need. Replacing the element should not be hard. Just disconnect the power first. My main concern is that you said the oven won't turn off. You may have a control switch problem. Did the element melt at the terminals or in the middle of the element itself?
Feb 15, 2009 | Maytag CWE4800A Electric Single Oven
Electrolux EOU6330 Electric Double Oven Logo
145 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
