Question about Casio Exilim EX-Z120 Digital Camera
Menu function wont operate nor will zoom best shot etc. tried removing battery etc.yesterday it was fine?
Connected a cable release the first operation of which has caused the shutter to "freeze". Error message reads r07. Display screen showing other functions such as auto focus, exposure readings,file size,...
1. Try removing the lens, fire off a few shots to confirm the mirror flips up and the shutter opens. 2. If that doesn't work, go into the menu and find "reset".
Aug 24, 2010 | Nikon D70s Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
IXUS 70 with black screen!
Did you accidentally press the lower-left DISP button on the back of your camera? This manually turns the screen on and off to save battery power. You would then use the optical viewfinder in its place. Try pressing the DISP button once to see if the screen turns back on.
Jun 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Fujifilm E900 camera zoom does not function!
If the shutter and Zoom function both do not operate, you need to send the camera to an authorised repair center. Was the camerra exposed to salt/sea air? If so, you can take a soft rag and gently wipe around the lens area where it meets the body, remove the battery, reinstall the battery and try it. If not, send it in.
Mar 20, 2009 | Fuji FinePix E900 Zoom Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Camera Zoom Feature
Awesome ! ! ! That works ! ! ! ... Turning off, removing battery for 30 secs., putting it back on, and reboot. Thanks ! ! !
Jul 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
Dsc-N2 Buttons are mulfunctioning.
Its possible the button board under the rear case has been shifted or is malfunctioning. You can try to remove the back case and see if you can realign, or reset your camera's button board. If this doesn't work, there are several online companies that can help -
DarnToothySam.com has several repair estimate opportunities, and is pretty reasonable for the price.
Dec 20, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Pentax s5z doesn't take any more pictures
Here's another method to fix this problem.
Push the ON Button for some while and you will go to MEMO recording screen, in this mode the MENU button works and you can RESET the camera.
Cheers Phil
Aug 29, 2007 | Pentax Optio S5z Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Canon a85 problem
Could be that the non-rechargeable batteries are blocking current from the rechargeable ones. Either get all rechargeable and charge them AT LEAST 14 hours before using, or use all alkaline - fresh. If the same display happens it could be a defective CCD which is being replaced FREE by Canon. Go here for details: http://www.imaging-resource.com/badccds.html
Nov 25, 2006 | Canon PowerShot A85 Digital Camera
Casio Exilim EX-Z120 Digital Camera Logo
23 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
