Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
My remote will not turn on the fan or the light. I have tried to change the channels on the remote and fan and still nothing.
    Genius:
  • 1,970 Answers
Mcdevito75 here Two things, is there electricity to the fan lights and fan itself?? then, did you change and install new batteries in the remote.??
Posted on Jul 21, 2010
My rc939 wont work unless right next to receiver.
Your description sounds similar to the problem ceiling fan owners have with their RF remotes. Try disconnecting the power to the pool light (at the breaker), pausing, and reconnecting power. Try remote operation. If nothing changes, reprogram the transmitter to the original setting and repeat the previous test. If nothing changes, the transmitter may have sharply reduced power output or the receiver may be defective.
Jun 21, 2014 | Intermatic RC939 3 Channel Radio...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Nov 04, 2007 | Hunter Vaulted Ceiling Mount - Antique...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
98 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
