Question about Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
My ps3 is dead!!!. when i start it, the green light turns on for about 3 seconds and then it comes back to a flashing red light after that, If i push the power button, the flashing red light passes to a stady red light. How i fix it???
    President:
  • 1,561 Answers
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Posted on Jul 20, 2010
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 at the back the red light comes on and when i turn the system on the green light comes on for about 2 seconds and then the system switches off it does this everytime i try to turn it...
It is the sign that your PS3 is dead by now. You overuse your PS3.
Try this maybe it works, pullout the HDD and reformat it
Then return it back to PS3.
If not, that is the sign of YLOD. mean yellow light of dead. If before this yellow color and then suddenly red. Note : It cannot solve by cooling the PS3.
If problem still exist and still on warranty, return it to sony for repair. G
Nov 24, 2010 | Sony Playstation 3 (PS3) Console
Green light then red/green light then flashing red
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation 3 back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My 12th old ps3 has been faultless until 6/2/10 .It will not boot up at all .The start up red light turns to green as per normal then after 2 seconds it flashes red and goes back into stand-by mode Any...
That is the PS3 "Red light of death"
The articles below could help you fix them :)
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
When I turn on my PS3 the light flashes green 3 times then yellow twice then red. It won't eject the game disk. I've tried holding the eject button for up to 30 seconds without success.
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony. North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
345 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
