Question about Compaq Presario SR1800NX Desktop PC
Maxtor harddrive jumper setting
Sorry to bother you again my compaq pressario >>>>> my hard drive i am not sure it's damage or i set the jumper wrongly >>> I will set it as a single drive , master . which I have done that but still got the same message . i tried to find it on the web still in the dark .. my hard drive that came with the system is
maxtor diamond max 10
model : 6L 100 PO
100 GB PATA 133 HDD
please help show diagram will be very helpful, if that dosen't work , then I'll buy a new hard drive . thanks a million .
  • 23 Answers
If you only have a single hard drive (or multiple hard drives for that matter), you should leave the jumper setting as "Cable Select" or CS.
See if this PDF matches your hard drive:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/quick_specs/dm10_ata_quickspecs.pdf
Posted on Apr 22, 2008
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
How do you set the jumpers the Maxtor Quantum Fireball Plus AS 20.5 GB hard drive
Jumper settings for Seagate and Maxtor IDE (ATA) harddrives,
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=196299&NewLang=en
Follow the chart examples under the second heading down >
Maxtor (and Quantum) drives follow the jumper configuration noted below.
If I may also add;
1) http://www.youtube.com/watch?v=Ds1-JmbhGRM
2) http://www.youtube.com/watch?v=WwbboeMO7b8&feature=channel
Nov 10, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
Need jumper settings for both hard drives. PCb board has been replaced. Cannot rememebr the orgional settings.
Master (M) on the harddrive that came with the computer, Slave, (S, or SL), on the 2nd harddrive.
Don't see M, S, and CS, on the label of the harddrive? (CS is Cable Select)
Sometimes it's right on the edge, where the 40 pin flat ribbon cable plugs in. It will be letters raised in the plastic, of the harddrive body.
To find where to set the jumpers for these harddrives, I suggest you look at the label. Since you had the Printed Circuit board replaced, I'm guessing you know who made it, and what the model number is.
Some harddrive manufacturers,
1.Western Digital
2.Maxtor, (Maxtor is owned by Seagate now)
3.Seagate
4.Hitachi
5.NEC (No longer in business)
6.Quantum, (sold out to Maxtor)
Here are three links that are videos, and may help with setting jumpers, and setting up those IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
(If you have SATA harddrives, do not touch the jumpers, if any are present! These are for the factory. With a SATA harddrive, you can plug it/them, into ANY available SATA header, {Connector}, on the motherboard. Doesn't matter!)
1.http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.http://www.youtube.com/watch?v=4inX3nC6M1E&feature=related
3.http://www.youtube.com/watch?v=KtEcwRqzeVo&feature=related
May 22, 2009 | Computers & Internet
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Need installation instructions for Maxtor 80 GB 7200 RPM Ultra ATA/133 8 MB Cache Hard drive for compaq presario sr1630nx microsoft xp
GET SUPPORT AT HP.COM FOR INSTALLING A HARD DRIVE FOR YOUR COMPUTER MODEL.GO TO MAXTOR TO GET SUPPORT FOR INSTALLING THE HARDDRIVE MODEL YOU HAVE.JUMPER SETTINGS,ETC.
Aug 22, 2008 | Computers & Internet
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Computers & Internet Logo
224 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
