Question about Apple iPhone Smartphone
How do i get it synced to my itunes when its disabled
    Problem Solver:
  • 35 Answers
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
Tells me iPad is disabled
Connect the device to the computer with which you normally sync and open iTunes. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes by pressing the "Back Up Now" button. When the backup and sync are complete, restore your device
Sep 26, 2015 | Apple iPad Mini
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
Ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPad is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
Hi iforgot my ipad pasword help now urgent
From the Apple Support website:
If you enter the wrong passcode six or more times, you'll see a message that says iPad is disabled.
If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device:
  • If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  • When the backup and sync is complete, restore your device.
  • When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  • Select your device in iTunes and choose the most recent backup of your device.
If you see one of following alerts, you need to erase the device:
  • "iTunes could not connect to the [device] because it is locked with a passcode. You must enter your passcode on the [device] before it can be used with iTunes."
  • "You haven't chosen to have [device] trust this computer"
iOS Forgotten passcode or device disabled after entering wrong passcode
Jan 30, 2014 | Apple Ipad 3 16gb Wi-fi Only Md328ll/a...
Forgot unlock passcode
Jan 28, 2014 | Apple iPad Tablets & eReaders
Apple ipod
from apple If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device:
  3. If you have chosen to encrypt your backup, it will contain the passcode. Disable backup encryption before restoring from backup. Learn more about iOS backups in iTunes.
Dec 07, 2013 | Apple iPod touch
In my phone i am using the screen lock with numbers passwords but now the password is not working how can i get back the password
If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device: Connect the device to the computer with which you normally sync and open iTunes. If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes. If you have chosen to encrypt your backup, it will contain the passcode. Disable backup encryption before restoring from backup. Learn more about iOS backups in iTunes. When the backup and sync is complete, select Restore from Backup and choose the most recent backup of your device.
Nov 22, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
I forgot my lock screen passcode
Sep 30, 2013 | Apple iPhone 4S
Apple iPhone Smartphone Logo
37 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
