Question about Insignia NS-DV2G MP3 Player
Is there a usb connection - Insignia NS-DV2G MP3 Player
  • 820 Answers
There's a manual in pdf format for the NS-DV2G on this page:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
There's a mini USB port near the earphone plugin: viewing the display and the scroll wheel on the right, the mini USB is on the right side.
All support for this player can be reached here:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Posted on Jul 20, 2010
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
Feb 12, 2016 | Kenwood Audio Players & Recorders
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
I can"t to download my new camcorder mpeg4 to my
Follow the steps below to troubleshoot if the computer does not recognize the USB connection from the camcorder.
  1. Turn off the camcorder.
  2. Ensure the USB cable is connected securely to the camcorder.
  3. Ensure the other end of the USB cable is connected securely to the USB port on the computer. NOTE: Connection through a USB hub is not supported.
  4. With the exception of the mouse, keyboard, and camcorder, remove any other USB connected devices from the computer.
  5. Turn on the camcorder.
  6. On the camcorder LCD screen, touch the computer or hard disk icon.
  7. If the issue is still not resolved, connect the USB cable to a different USB port on the computer.
  8. If the issue is still not resolved, try uninstalling and reinstalling the USB driver
  9. If the issue is still not resolved, test the USB port on the computer by connecting a different USB device.
Jan 01, 2011 | Video Cameras
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Usb 1.0 or usb 2,flatbed scanner compatability
Find a USB device, such as a memory-stick, that is "USB 2.0" and connect it to a USB port. If Windows XP pops-up a window ("this device will perform better when connected to a USB 2.0 port"), then you have connected it to a USB 1.1 port.
Yes, you can connect a scanner, if it has a USB connection. Not all laptops have a parallel-port ("old-style" printer) port, but some scanners require a parallel-port.
Jan 29, 2010 | Computers & Internet
My mac won't connect with my dcr-sr47camcorder
  8. If the issue is still not resolved, try uninstalling and reinstalling the USB driver.
  • If the other USB device operates, the USB cable may need replaced or the camcorder may require service.
  • If the other USB device does not operate, then the issue is being caused by the computer. If the computer is connected to a network, try disconnecting it from the network or connect the camera to a computer that is not on a network. In addition, mapped drives may cause connection issues; drive designations D, E, or F must be available. It may be necessary to contact your system administrator or computer manufacturer.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C455202
Jun 19, 2009 | Sony Video Cameras
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
USB Connection. When connected to computer camera shuts off or displays USB error.
you have a faulty usb cable. try to buy another usb cable which supports usb2.0 for faster data transfer.
Mar 23, 2008 | Cameras
Connected through a 4-port USB hub
Use of a USB hub for connection does not guarantee normal operation. Try attaching the USB cable directly from the D-snap SD Camera to one of the built-in USB ports on the PC.
Aug 31, 2005 | Panasonic D-Snap SV-AS30 Digital Camera
Insignia NS-DV2G MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
