Question about InFocus LP 530 Multimedia Projector
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
  • 22 Answers
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Posted on Jul 21, 2010
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
Replaced bulb. Worked for a while then wouldnt power up again.
the cheew cheew cheew is the colorwheel not spinning properly. either the colorwheel motor is shot, the sensor can't sense it, or the power to it is too low. first thing: remove the cover and blow the dust out of it with canned air. dust does a lot of damage to these. if it is the sensor, cleaning it off might help. if it is the colorwheel, i have bad news: on the x1, the colorwheel is not sold seperately from the optical engine. you'd have to get the entire optical engine. now the worse news: infocus no longer makes or sells parts for the x1. you could try and find one on ebay that has a different problem and swap out the parts
Dec 29, 2009 | InFocus X1 Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Infocus X1a LONG startup times
Sounds like the power supply is weak if it has to run for awhile before it functions. The control board could also be the issue. Does it make any grinding or buzzing noises?
Jul 18, 2009 | InFocus Televison & Video
Fan operates on x3 but no picture
Very likely your bulb. Could also be your ballast.
Jan 08, 2009 | Office Equipment & Supplies
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Infocus lp530
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
Jan 08, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP 530 Multimedia Projector Logo
360 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
