Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Not despensing ice
The ice maker works and make ice but the, but the unit will not despense the ice itself.
  • 166 Answers
Make sure the ice bin is pushed all the way in position. Also make sure you don't have a big clump of frozen ice blocking the auger and keeping it from working.
It is a good idea once in a while to take the ice bin out and completely wash and clean it out real good.
Posted on Jul 20, 2010
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 08, 2010 | Whirlpool Refrigerators
Our ice maker stopped working but it still despenses water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
wryt
Sep 19, 2010 | Whirlpool GD5SHAX Side by Side...
Water is forzen in cube despenser but does not dump out
heatman101
Aug 27, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Hi,I have a GE 42" Monogram refrigerator,model # ZISW42DYB,serial #LS037072. The problem that I have is the freezer is leaking water even if I turn the ice maker off.In a day or two the ice tray fills with...
Good day Paul.
Sounds like your diagnosis is right on. In extremely rare cases the ice maker itself could be at fault. But once again is extremely rare.
Dec 12, 2009 | Refrigerators
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice Maker
ice Freezs in storage tray
Apr 19, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Kenmore elite side by side refrigerator
do you hear the little click of the switch when you push the paddle?? Its likely that the microswitch had broken from its plastic mounts. Pretty common on this refrig. ill need the model # to be sure what kind it is.
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
145 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
