Question about Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor
Grey white screen and that is all
My Monitor seems to be connected properly to my PC but all I get is a grey white screen. Does this mean the monitor is bad or does it mean the monitor is working because I get the grey white screen? Mike
  • Anonymous Nov 30, 2008
    i have that same problem. The pc will turn on fine but when i switch the monitor on it goes white /grey and thats it! what can i do??
  • 180 Answers
Hi Mike,
Probably defect at the logic board of LCD.
Posted on Apr 22, 2008
2 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: grey white screen and that is all
It looks like you will have to get the backlight replaced/fixed.
Posted on May 20, 2008
Why is my Philips brillance 220cw Monitor showing white screen?
that is what we can assume . some can be repaired most can not
Jul 28, 2015 | Philips Computers & Internet
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
When I open my computer, I get a white screen. What is the best of fix this?
Buy a new computer from the sound of it, or take it to a repairer, if the screen is white instantly after power on, there is noting that you can do yourself.
May 23, 2011 | Acer Aspire 5742Z-4200 Notebook
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Dell Latitude XT2 fails to start up.
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Sep 23, 2009 | Dell Latitude XT2 Tablet PC
The screen comes on, but is white/grey. Connected laptop to PC monitor, the motherboard seems to be OK. How difficult is it to buy a new screen and install it? Should I have it professionally looked at?
Since your video is ok on the external monitor,this could be a problem with the cable that runs from the laptop up through the hinge to the screen. I would definitely adivse you to have a professional check this out. If the laptop screen is defective, it is extrremely expensive to replace. Get more than one quote for the work.
Jul 28, 2009 | Toshiba Satellite M35X-S111 Notebook
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Monitor is busted
Hello David,
I think along the lines like you. $500 dollars is a good chuck of money and alternatives would be my first choice. My suggestion is to check both ends of the cable harness the plugs into the screen and to the mother board. Make sure both ends are inserted properly.
Next thing is to test - power up the laptop and see if that made a difference. If not, it may be the screen or the motherboard. So test further by pluging in an external monitor to check to see you get a good picture/image. If so, then that means you need to replace the laptop screen. If you dont get a good picture/image, than that means your motherboard needs replacing.
Hope that helps and good luck.
Jul 20, 2008 | Dell Inspiron 700M Notebook
May 20, 2008 | Gateway FPD2275W LCD Monitor
Dell e173fpf lcd monitor is grey
Sounds like the AD section of the board may be junk. I did the same thing - bought the board from lcdrepair.com.
I submitted an RMA request to get a replacement. The process was difficult due to the pdf form they make you fill out. Lots of errors and no good way to submit it, since it wants to use outlook, but the pdf isn't configured properly to do so. Seems fishy, but I'm giving them the benefit of the doubt for now. We'll see.
Nov 10, 2007 | Dell E173FPf 17" TFT LCD Flat Panel...
Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor Logo
649 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
