For Shastalaker7, I had the earlier problem with the ruud ac...please see my comments to i added to that...i believe i hit the wrong buttons when accepting or adding to the conversation on that
    President:
  • 2,047 Answers
Hello there, can i be of assistance to you?
Posted on Jul 20, 2010
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Ruud furnance/ac central air
i can help u but mikep858 i need u to give me the model of this ac okay the correct one
best regards
Aug 14, 2008 | Ruud Central System Air Conditioner
When I turn my AC power on, the reset button pops out and the unit turns off. This happened yesterday, but then I hit the reset button and it was fine. Today, that is not working.
If it ran fine all day after you hit the unit, it sounds like its just the reset button that has the problem. What you can do, is turn off the power to the unit and pull this reset button out enough to get to the wiring. It should have the same wire going in one side and out the other as it is just a switch. Take a jumper wire and bypass the button. In other words just connect a piece of insulated wire and connect it from one terminal to the other, and this takes the button out of the system. This will be a temp. fix only, until you can get another at a appliance parts house. If its just wore out and there is nothing wrong with the unit, it will run. You say it was fine when you hit it that day? If it ran for the day, its just a faulty reset button, so just bypass it. Be sure to use black tape to tape any bare wires. Please don't forget to rate me as I know you will be kind to me. Please keep me posted on this also by my user name below. This will solve your problem until you get a new one.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 06, 2010 | Whirlpool Heating & Cooling
I have a Ruud AC DATE: 12/00 Model:
Here is a tip about trouble shooting your air conditioner...
I would check the air filter and the blower motor...
sounds like a problen with one of them...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 20, 2010 | Ruud Heating & Cooling
Our Ruud achiever heat pump's ac will not kick on?
Hi, there is no reset button for your high pressure switch. You need to see if you have lost power to the unit. Check the circuit breaker. By the unit, you will have a electrical box, disconnect. Raise the cover and pull the plug. You should have 2- fuses there, most do. If you can't see any go one step further by removing the plastic cover and see if they are in there. If so, try replacing both fuses. This is where you need to start. You will have high voltage to the unit such as 208/230 and control voltage from the stat and indoor unit of 24 volts. Find out and make sure you have high voltage first and let me know. Use my user name below, and get back to me, we may have to go into it more.
Sincerely,
Shastalaker7
May 22, 2010 | Ruud UAMB Air Conditioner
We need an owners manual.
Hi, looks like you have a 21/2 ton Ruud split system by the numbers. Let me look this up and see if I can find a manual for this unit and send you a link to down load it. Give me sometime please. Be back soon.
Shastalaker7
May 08, 2010 | Ruud UAKA030 Air Conditioner
Looking for a manual for RUUD model number 92212650402
Hi, you can get a manual from your local Ruud, Rheem wholesale parts house. If not, go online and you should be able to down load one. Just have the model, serial, and product number if there is one handy.
Good Luck, Shastalaker7
Nov 03, 2009 | Ruud UBHC Air Conditioner
RUUD Acheivers Series AC unit
The reset is two pins on the defrost board. Put a flat scredriver across them to reset the board.
Aug 15, 2009 | Ruud UBHC Air Conditioner
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
May 11, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
