Question about Sony Playstation 3 (PS3) Console
During play the ps3 automatically turned off. Now it doesn't turn back on. Plugged into several different other power outlets to no avail
    Scholar:
  • 41 Answers
PS3 automatically turn off means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such automatic turn off problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Posted on Jul 23, 2010
I have a 922 printer and it won't turn on.
Did you try plugging the printer into a known live outlet? If the outlet tests good and has available power, check and make sure that no panels have come loose and could have tripped a safety switch during your move of the printer which could cause a no power up issue to prevent damage to printer. If still no luck, try a different power cord and se if that works. Hope this helps.
Mar 10, 2014 | Dell 922 All-In-One InkJet Printer
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Went on vacation and left the PS3 powercord unplugged. Now it doesn't work, could it be the cable?
Hey there, a couple of things to verify here to get your ps3 back up and running. Do not worry about leaving your ps3 the whole week with the powercord unplugged, this is OK and should't have affected anything negatively.
1) Make sure that the powercord is well plugged on both ends: ps3 AND in the wall.
2) Make sure that the SWITCH is turned on (in the back of the ps3, there is also a POWER switch I/O). Turn it on by pushing on the I.
3) If it's still unpowered, try plugging the ps3 itself somewhere else in the house (to make sure it's not the power outlet)
Jun 23, 2011 | Sony Playstation 3 (PS3) Console
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 with no Power?
it might be the wall plug try a different one
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Screen has has horizontal white lines and a loud buzz with ps3.
it could be that your rca cables are damaged, you can try using different ones, or it could be that you have a setting to use rca cables turned off in your settings of the ps3.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 starts but wont turn on
you could have a problem with your power cord which is causing your ps3 to short before the system can power on fully. try using a different power cord or check the ports of both the outlet and the ps3 to make sure there is nothing blocking anything. also, try using a different outlet.
Oct 14, 2008 | Sony Playstation 3 (PS3) Console
Out of Range
Do you have power to the base? I've seen this message on several cordless phones if the base is unplugged, the power brick has failed or the power adapter was plugged into a power strip (or surge protector) that has been turned off. It can also happen if the circuit breaker for that outlet has tripped.
First check that the power adapter is plugged into an outlet and the other end is plugged into the base. If the power brick is cold, check that the outlet has power by plugging in a different device (like a lamp) and turning that device on. If there is power, than you need to replace the power adapter or the entire phone (if you can't match the amperage output of the adapter). If there is no power at the outlet and the adapter is plugged directly into the wall outlet, check your circuit breaker for that outlet.
If you used a power strip or surge protector, check if it is on. For a surge protector, check if the surge protection circuit light is on. Replace bad surge protector.
I hope this helps.
(I have seen someone intentionally turn off a surge protector during an extended power outage and then fail to turn it back on after power returned. The individual forgot that they had turned things off before they called for assistance with their phone.)
Aug 17, 2017 | GE -25893GE3 Cordless Phone
Wont turn on
I don't think the outlet you are plugging it into has enough power to support the ps3. Try plugging it into a different outlet and see if it works.
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
