Question about GE WSXH208A Front Load Washer
WHERE AND HOW DO U CLEAN UR PUMP - GE WSXH208A Front Load Washer
  • 1 more comment
  • adelar1071 Jul 20, 2010
    I have an GE front loader, which washes with 4 spins then drains the water out then sits their while I can hear some motor running for awhile then shuts off. I have unplugged it for 2 days and plugged it and does the same thing. I have check the drain and the unscrewed the big plug in the front of the washing machine. It drains little water and there are no articels in there.
    Thank you dearly, this machine has been in shop second time. I really do not like these machine.
    THANK YOU VERY MUCH I WILL CONTACT THE LOCAL APPLIANCE CENTER TO PURCHASE A PUMP
  • 6,784 Answers
HI. Every front loader is different. The pumps are placed in different arrangements and the filters are , as well. In order to increase accuracy, i will need to identify which unit you have. Please post the entire model number associated with the affected unit, asap.
Thanks..
Posted on Jul 20, 2010
  • Michael Masters
    Michael Masters Jul 20, 2010
    Ok, you will need to remove the bottom service panel to access the the filter and pump device. Once the service panel is removed, you can can pull the pump clean out filter out of the left side of the pump. Clean the filter out and replace it.
    Click here to be directed to a service manual that will help you will the process of removing your service panel.
  • Michael Masters
    It would have been really nice to see that information in your initial post....
    The culprit here will be your pump impeller. it has failed. You will need to replace the pump............
Our washing machine keeps coming up with a red
Fill the washer up put it in drain and lift the drain hose out of the stand pipe and look at the rate of flow,if the vault is clear the the flow will be strong if not take the pump apart again and see if something else did get caught or check your partial blockage . There is indirectly a relation between door and drain but after resetting to preset even no changes so sharply look to symptoms exactly what is happening, suspected thing i can say in ur machine maybe ur door safety switch is faulty close the door properly........... is that fully electronic instrumentation or electromechanical, and also you may take care of the door gasket while operating.Sometimes if there are things in the pump it can damage the pump so when it is cleaned out the pump is still damaged, if problem still persist you may need a new pump.
Sep 18, 2014 | Washing Machines
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
We have a 2002 Chevy Suburban and it cuts out while driving down the road, about 20-30 mins after starting the vehicle. We've cleaned the fuel filter. As soon as we crank it up it'll run for 20 mins than...
there is code that does not turn on the service engine soon. have code retrieve.And when the problems occured have fuel pressure check.You have to find out if the problem is electrical or fuel and air .Another way to find it is move engine harness while engine running if it stall could be short to ground or wire cut open
Aug 28, 2013 | 2002 Chevrolet Suburban
My 2005 mpv dies while I am driving when I let off the gas quickly. It reads that it is running lean o2 sensor bank one and two.
Running lean means the ur car is not getting enough fuel for complete combustion. Your O2 sensors have picked this up from the readings. Be sure to check what could be causing this problem soon b4 ur catalytic converter is affected. Check ur fuel line, service ur injectors, change fuel filter(it could be clogged) n check, fuel pump pressure n if d tank is really dirty while u re at it **** out d fuel n clean the tank t
Sep 07, 2011 | Mazda MPV Cars & Trucks
Powesteering not working pump gets very hot took tank off toclean started after that
it sounds like u didnt install the valve in the high pressure line at the pump correctly...or the pressure valve is stuck....ur best bet is to buy a new pump since u had to clean it the p/s system is probably contaimanated .....the pumps r cheap to buy an can be bought at any parts store
Jul 15, 2011 | Chevrolet Corvette Cars & Trucks
Van lost power going up hill, now goes on flat rds about 100 mtrs then dies. nissan serena
There are 3 reasons for this:-
Worn out piston rings
Clutch Plate worn out
Fuel pump not working properly.
Better will be to take it to a garage and have it checked for these defects.
Jun 06, 2011 | Nissan Sentra Cars & Trucks
Pressure on my Goulds 2000 pump went from 60% to 20% after major storm.
Hi im Rossouw
Its pretty comen for minisepal pipes to burst during a big storm due to more presure, also more lickly in winter. i lookt up the pump bt dident realy get speks on it bt i will bet that there is ground in the bilt in filter of the pump, cleaning that out is not recomended if u dont know how, i would get a plumber in and also install a big filter befor the pump to ensure that it dosent hapen in the future.
I am a plumber and if u do want to try to clean it ur self ill read up about ur pump and direct u. thast let me know.
Plz rate my advice or exsplenasion. help me help more ppl thanx!
Jul 11, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Back disk brakes will not bleed
because ur letting air back in the way ur doing it fill reservoir with brake fluid this might b easier with u and a partner pump brake and hold-while holding open brake bleeder let handle squeeze in dont release keep squeezed in now tighten bleeder and pump the brake continue bleeding till brake is normal about 5 times
Apr 07, 2009 | 2004 Factory bike Desert YR 250
My fuel pump does not hum and I want to replace it can you tell me where the fuel pump is located? is it in the tank?
YES THE FUEL PUMP IS IN THE TANK UR GOING TO HAVE TO DRAIN ALL THE GAS OUT AND REPLACE THE PUMP IF ITS BAD BECARFULL WHEN U ARE WORKING WHIT THE GAS TANK ALWAYS HAVE A WET TOWEL NEXT TO U TO CLEAN THE PROPS OF GAS HOPE THIS HELPS
Feb 19, 2009 | 1990 Ford F150
Won't idel
can seafoam clean carbon from the egr vavle for the gas and motor let ur car man clean the egr valve run some stuff in it motor getting carbon due to sitting and sends it through ur egr
Dec 23, 2008 | 1994 Chevrolet S-10
GE WSXH208A Front Load Washer Logo
50 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
