Our Carrier central air is unresponsive, nothing at all, no noises, air handler and condenser unit will not turn on, please help me before I lose more weight in my 150 degree attic. The serial # for the air handler is 0695803341 and the product # on AH is FB4ANF030000ACAA / we only have central air, system is not connected to any heat source Early sunday morning I turned the T stat to the off position, when i came home a few hours later I turned it back to the on position and nothing at all, no clicks or sounds of any kind. I checked the breakers at the panel, the service switch at the air handler, the fuses (installed exact replacements) at the exterior disconnect and still nothing. Our t stat is the round mercury type, which my in law thought might be defective, so we jumped the red and white ( I have Red, White, and Green), and still nothing. I got out the mutimeter and tested the LV volts at the T stat and with muti-meter set to 200v the reading was 03.7v. At that point we moved to the air handler, checked the 5 amp fuse on the PCB and it was not blown. Checked the volts at the low voltage wires , the readings were 03.7v. The volts at the transformer read 115v and 115 v input, output 03.7. Later I went outside to the condenser unit and visually inspected the contactor , nothing noticable no damage to the contacts. I pushed it in with a insulated screwdriver briefly and the fan and compressor came on. Then I tested the low voltage coming in , no reading. I also checked the LV at the contactor coil, nothing. I assumed, or we assumed, it was a bad control transformer. Installed new control transformer and nothing still not a click or sound of any kind. I did some volt tests with the mutimeter , the readings are 05.6v at every LV connection ( AH, Condenser, and T stat). Although at first I had no reading at the condenser and contactor coil. I ran a temporary 18G wire to the condenser from the air handler, only then did I get a Lv reading of 05.6. This was at 2 am this morning and was the last thing I tried with the same results , nothing. Thank you in advance for any assistance you can offer me
  • 456 Answers
I think you need to slow down and start fresh.
1) You have 115v at Transformer-You are reading from Red to White
on windings?
2) If that checked out OK are you reading 24v out of Transformer?
3) If yes, remove thermostat wires and put a jumper wire between
R and G. Put the Blower Door Back ON and turn on power
hopefully your fan will come on.
4) If the fan comes on, move the jumper between R and Y, put the
blower door back on and turn on power, indoor fan should come
on as well as the outdoor unit. If the happens you have a problem
with the low voltage wire being broke or a defective thermostat.
5) If none of the above happens and you do not have 24v Between
R and Y or R and G, but you have 24v on the secondary side
of the transformer, you have a defective control board.
Posted on Jul 21, 2010
My air handler is in the garage and the out side of the unit has started to condensate between doors and along the bottom of the doors.
The condensation is from air leaks or torn or missing insulation in the air handler cabinet. You can try replacing service panel seals and repair any damaged insulation. This should help but you probably will not be able to stop it completely.
Sep 01, 2011 | Carrier Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
Where is the filter located?
Hi, if this is a central system that is split up with the condenser outdoors and the air handler indoors it can be in the indoor unit it self or also it may be in the ceiling or wall near the unit behind a grill for the return air to flow back. Walk around and look for this grill. It is either up high near the air handler close to it, or low on a wall near it. If not out in the home, you will find it in the indoor unit only, nothing outdoors. If you remove a panel you should find it. Please keep me posted and please don't forget to rate me as I no you will be kind. I will check in on you a little later to see if you have found it.
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Goodman Heating & Cooling
Central Heat and Air noises.
Hi, It sounds to me that this split system you have is a heat-pump and not a gas fire air handler. The noise that you are hearing must be the freon in the copper lines equalizing in the system upon shut down of the compressor. All systems must and will go through this sequence. It shouldn't be that loud though. The copper lines should have armor flex on at least the larger suction line for insulation and to keep it from condensating everywhere in the summer in the cooling mode.If you find it is bare with nothing on it, you can buy this insulated tubing at Home Depot or O.S.Hardware. Its black in color and is split down the entire 10' section with glue covered seams on it. This should cut down the noise. Depending on the unit size Tonnage wise, the suction line may be 3/4" or 5/8" in diameter.Just ask for there water line insulation and like I said it comes in 10' sections and is very cheap, 20cents a foot or so. Please keep me posted if this does not take care of the problem. It may be coming from the lines where they enter the air handler. I will wait for you're reply.
Sincerely,
Shastalaker7
Jan 21, 2010 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
A/C thermostat wiring problem
call a technician
check all indoor n out door wiring of unit
if u do wronge connection wireing of unit may be burn
take care
Apr 04, 2008 | Heating & Cooling
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
