First check the door switch,push the paddle in and out,if it doesn't click you have a bad door switch.if that's ok check the thermal fuse,if the filter is on top of the dryer the fuse is in the back if the filter is inside the fuse is in the front located on the blower wheel housing.if it's the thermal fuse most likely you need to clean out the dryer.remove and clean out the duct that the lint filter slides into,vac out the inside of the dryer where the motor is and clean out the vent line and the vent outside.if it's a long run from the back of the dryer to the outside i use a leaf blower to blow out the vent line.the part number will be a 3392519 if it's a round thermal fuse it will be a 3390719,these are the most common thermal fuses,next time send the model number and i can look up your machine,let me know how you make out.if you don't clean the dryer the fuse will pop again
