Question about Vacuums
I have a lemon Hampton Bay 52" Redington III and the highest speed is stuck on medium (about 100 RPM), but all 3 speeds are different, and I have seen those fans in Philly Diner faster than that. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Vacuums Master
  • 6,993 Answers
please can you rephrase this question so that an accurate solution can be proffered? I don't really understand the question and its not clear enough.
I look forward to your reply.
Bye for now.
Posted on Aug 04, 2010
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
Hampton bay fan pull chain broke. The electrician took the light kit down and all four wires had come out of the pull switch he could not install replacement switch without knowing which wires went to...
1. Open the switch housing of the fan. This is usually achieved either by removing two screws on the bottom cap of the switch housing, or three screws on the side. Remove the pullchain assembly by unscrewing the brass finial on the outside of the switch housing.
2. Make careful note of which wires attach where to the pullchain. The chain itself will be marked L-1-2-3 or A-B-C-D or similar, the wires will customarily be of different colors, but if not, mark both the wires and pullchain if necessary. MAKE CAREFUL NOTE OF WHICH WIRES ATTACH WHERE. Every fan is different and if you do not make note there will likely be a complicated guessing game. I cannot stress this step enough. Make careful note of which wires attach where to the pullchain. For example:
Black - L, Grey - 1, Brown - 2, Purple - 3.
Some fans may use only two or three wires, some may have a pullchain with two layers and five or more wires. Regardless, make careful note of which wires attach where.
3. Remove the wires from the pullchain. In some cases they may be attached via wire nuts, in which case, remove the wire nuts. However in most fans the wires are inserted directly into the pullchain. Don't make the mistake of cutting them, they can be removed completely by inserting a very small flathead screwdriver into the slot next to each wire. You will notice the ends of the wires are soldered, this is so they will attach to the pullchain.
4. Determine the correct replacement pullchain. This is the tricky part. Many pullchains look alike but in fact switch differently. There are a few factors, first of all, how many speeds does the fan have as controlled by the pullchain? Second of all, how many wires are used to connect the pullchain? These will determine maybe 75% of replacement pullchains. Here are some examples:
- If the fan has three speeds and the pullchain has four wires, it is most commonly a L-1-2-3 pullchain. This is a single pole triple throw switch with an off position. It connects the power from L to 1, 2, or 3 respectively, one for each speed.
- If the fan has three speeds and the pullchain has three wires, it is an L-1-2-1+2 pullchain. This is a single pole double throw switch with an off position and a "both" position. That is to say, in connects power from L to 1 or 2 respectively, and on the third position connects to both. This is the same switch used in many lamps to switch on one bulb (or set of bulbs), the other, or both.
- If the fan has two speeds and the pullchain has three wires, it is most commonly a L-1-2 pullchain. This is a single pole double throw switch with an off position. It connects the power from L to 1 or 2 respectively.
- If the fan has three speeds and the pullchain has more than four wires, there are a handful of different pullchain possibilities however most hardware stores stock the most common replacement. This would customarily be a double pole switch with two layers of wires attaching.
The replacements mentioned above are the most common examples . . . but as I said, there are other switches that may appear identical (for example three speed fan, four wires, but it's NOT the first switch I mentioned). In most cases I would first try the replacement mentioned above. These are the switches that your local hardware store should stock. If the fan does not work with the likely replacement, does not work on all speeds, spins too fast, too slow, etc . . . and you are sure you properly noted which wire connected where on the old pullchain and wired the replacement correctly . . . then it appears your fan is in the 25% that uses a non-standard switch. There are three ways to determine the correct replacement switch:
- Contact the manufacturer. If they are still in business they can theoretically send you the correct replacement switch. If they are no longer in business, contact someone on our forums or other ceiling fan experts, we/they may be aware of the correct replacement for your particular model
- If you can still switch speeds on the old pullchain, use an ohm-meter to check for continuity between the various wires on the various positions. In most cases the important relationships are between L and the various other positions, for example a three speed four wire switch might be L-1-2+3-3. This means in the first position L connects to 1, in the second position L to 2 and 3, in the third position L to 3, fourth position off.
- If you can not operate the switch, you can open up it's plastic casing, either to operate the switch by hand, or to observe the metal bands inside. Some websites that sell replacement switches offer diagrams of the metal bands, by matching your switch up to the diagram you can determine the correct replacement.
5. Ok, you've determined and obtained the correct replacement switch.Seeing as you made careful note of which wires connect to where on the old switch, reconnect the wires in the same manner to the replacement switch. If your old switch did not require the tips of the wires be soldered you may need to do so in order to properly attach them to the pullchain.
6. Reattach the pullchain to the switch housing and replace the finial. Replace the switch housing cap with the two or three screws.
Additional Notes:
I. Fan lights where the pullchain is simply on/off use a two wire pullchain. This pullchain is a very standard on/off switch and it is simply connected to the two wires to which the old pullchain was connected. The wires can be reversed and it will still work. Lights where you can select one bulb, the other bulb, or both use the pullchain mentioned with that example above.
II. Some fans do not use the pullchain to control speeds, but instead have a dial or other control on the fan for speed selection. The pullchain is used to turn the fan off and on, and in some cases also to reverse the fan, select between the high speed and the various low speeds derived from the speed control, or also control the light. In these various examples:
- When the pullchain only switches the fan on and off, it most likely has only two wires and is equivalent to the light kit pullchain mentioned above. It is a basic on/off switch
- When the pullchain reverses the fan or switches the speed control in and out of the circuit, it is most likely the three wire two speed pullchain mentioned above. It is a L-1-2 switch. There are some exceptions such as certain model Fasco fans.
- When the pullchain controls both the fan and light, it is the three wire three speed pullchain mentioned above. It is a L-1-2-1+2 switch.
III. If for whatever reason you do not know which wires connect to which locations on the pullchain, you may yet have some options. For starters, black is almost always L. Some other common color combinations:
For many four wire pullchains:
L - Black, 1 - Grey, 2 - Brown, 3 - Purple
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
L - Black, 1 - Grey, 2 - Brown, 3 - Green
L - Grey, 1 - Yellow, 2 - Purple, 3 - Black
L - White, 1- Black, 2 - Blue, 3 - Yellow
For many three wire pullchains:
L - Black, 1 - Blue, 2 - Red
May 02, 2011 | Vacuums
Trying to find a replacement globe that is transparnt or translusent for a hampton bay 31133-22
Hampton Bay (Home Depot) has a toll-free number for you:
(877) 527-0313 (Monday - Friday 8 a.m. to 6 p.m., EST)
Mar 02, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Oct 11, 2010 | Vacuums
Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
1935 KIRBY Model R*
19?? KIRBY Model 2R
19?? KIRBY Model 3R
19?? KIRBY Model 4R
19?? KIRBY Model C
1939 KIRBY Model 2C
19?? KIRBY Model 3C
19?? KIRBY Model 4C
Model 505 - 1945
Model 508 - 1948
Model 509 - 1949
Model 510 - 1950
Model 511 - 1951
Model 512 - 1952
Model 513 - 1953
Model 514 - 1954
Model 515 - 1955
Model 516 - 1956
Model 517 - 1957
Model 518 - 1958
Model 519 – 1959
Model 560 - 1960
Model 561 - 1961
Model 562 - 1962
1963/64 Sanitronic VII (Sirocco)
1965-67 Dual Sanitronic 50 (Sirocco)
1967-70 Dual Sanitronic 80 (Avocado green)
1970-73 Classic 1CR (Medium brown, gold bag)
1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
1976-79 Classic III 2CB (Candy-apple red, plaid bag)
1979-81 Tradition (Dark blue; intro of paper bag)
1981-84 Heritage (Gray/orange)
1984-89 Heritage II Legend (Charcoal/gray/red)
1989-90 Legend II (Dark rose-pink)
1990-93 Generation 3 (Alabaster)
1993-96 Generation 4 (Medium gray)
1996-99 Generation 5 (Maroon)
1999-01 Generation 6 (Black/Yellow)
2002-05 Kirby Ultimate G
2005-06 Kirby Ultimate G Diamond
http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How to remove a Hampton Bay Cameron Plus Blue Ceiling Fan?
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Aug 29, 2010 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
I don't get not power after attach the hose?
Bad power switch
Switch is designed to run motor on higher RPM when hose is connected. The high speed lever mechanism failed and you need the new switch. You can find it HERE. Instructions how to replace it HERE. We can do it for you (labor $50 plus the part It includes shipping of the unit back to you. I am assuming you are within continental USA)
Rocky
Apr 03, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
