Question about Longines L2.673.4.78.6 Watch
In my Longines Automatic watch , how to set the second time in watch (the small dial with hr and minutes hands)
SOURCE: Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Posted on Mar 28, 2008
gemdealer
  • 7 Answers
SOURCE: how to access older timex automatic watch second hand
You should be able to open the back by popping it off with a sharp knife blade. Sometimes, the lip where you'd open it is hard to see and usually under the band, between the lugs. The movement will just come out. If I read you right, you know how to do this, once the movement is removed. You can't just pull the hands off. Hopefully, you'll be able to just VERY EASILY bend the one that is causing the problem.
Posted on Feb 17, 2009
  • 55 Answers
SOURCE: The second hand stops for a few seconds. It then
that is an EOL function, in other words an "End of Life" warning...the watch is telling you that the cell has become low and needs replacing, some movements have this function
Posted on Nov 09, 2009
Testimonial: "Thank you for the technical diagnosis. I will get the cell changed asap."
  • 2501 Answers
SOURCE: how do i set an older longines automatic admiral
You can get instructions from their web site but if your watch is really old, then it seems unlikely that any of the instructions there are for your watch.
However, since watches tend to have similar features (although not the modern electronic types), a basic modern watch probably operate in the same manner.
Go to "www.longines.com/watches/instructions" and have a look at the range of instructions there to see if they are any help.
If nothing useful is found look at the "official retailers" to see if there is a local shop that can help you.
Posted on Mar 09, 2010
  • 906 Answers
SOURCE: Setting Longines Evidenza L2.643.4.73.4
Good day sir, You can download the users manual of your Longines watch here. click the link below and select english.
users manual
Posted on Jul 28, 2010
Mk 5473 watch is loosing time
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
Mar 26, 2013 | Michael Kors MK5473 Ladies Logo Watch
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Dear Sirs! My new (1month) Longines automatic watch hastens each day (and night) four seconds.Model L4.721.2 Is it normal or I have to turn to the laboratoty to fix the problem?! Thanks a lot Iosif
An automatic watch that gains 4 seconds in a day is good.A new Rolex is rated at 5 seconds per day so 4 seconds is well within what you can expect for your watch.As a tip when the watch is off the wrist place on its side,gravity slows the operation of the watch just a fraction.This is called positional error and may help.
Regards
Aug 19, 2010 | Longines New La Grande Classique Presence...
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
Watch is loosing time
mcdevito75 here, Best Bet for your Longines watch, visit a small watch repair shop in your area for this timeing adjustment.
Jun 27, 2010 | Longines 2 Tone, Automatic, 1970s Watch
The second hand stops for a few seconds. It then rapidly proceeds through 4 or 5 of the minute markers. The watch is still keeping time.
Nov 07, 2009 | Longines Evidenza L2.643.4.73.4 Wrist...
users manual
Apr 04, 2009 | Longines Evidenza L2.643.4.73.4 Wrist...
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Mar 11, 2008 | Longines Watches
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Longines L2.673.4.78.6 Watch Logo
149 people viewed this question
Top Longines Watches Experts
michaelrt616
Andrew Taylor
Andrew Taylor
Are you a Longines Watch Expert? Answer questions, earn points and help others
