Question about Bunn BT10B Coffee Maker
When I turn the coffe pot on the light and everything turns on and it gets warm but the water doesn't come out. I shut it off for 2 hours and turned it back on and it started up then stoped again and just barely dripped.
  • 21 Answers
Sounds like a float is stuck in the shut position. You might need to take that to a service technician to double check that operation. Sometimes lines get scalled up with hot water deposits.
Run vinegar through the maker and see if that helps.
Posted on May 26, 2008
I just bought this coffee maker. I love it but the most I can program it to keep my coffee hot is 4 hours. I want it hot all day. What can I do? When it goes off, I can't even turn it back on again, even...
It is supposed to hold the coffe hot for 59 minutes , no more . After that it shuts off , fire hazard . Then you are supposed to wash it and make new coffe . Coffe after one hour tastes burnt , no good . Always make fresh new coffe .
Oct 28, 2013 | Cuisinart DCC-1200 Coffee Maker
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I can program or not and just brew. The coffee maker will change the clock time, how many hours the pot stays on (2-4) and just shut off automatically for no reason. Any help would be appreciated. ...
the coffe make is on a sencer timer built in coffe make for securty reasons its shots off after so many min. they built them that way so just in case someone forgets to turn off coffe maker and no ones home and burnes the place down.
Feb 24, 2011 | Cuisinart DCC-1200 Coffee Maker
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
Water will not pass through seems clogged
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Apr 24, 2010 | Cuisinart DCC-1200 Coffee Maker
My 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
Mar 20, 2010 | Cuisinart DCC-1200 Coffee Maker
Why does the plug loosen and my coffee is cold after pouring???
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Dec 13, 2009 | Faberware FCP240 Coffee Maker
Coffe first pot is hot after that they are cold
This can be caused by scale build-up on the thermostat probe that hangs inside the tank. The scale stays hot for a long time, tricking the thermostat into believing that the water is still hot. Try pouring 1 Qt white vinigar into the unit, let it warm up completely, run a pot of clear water thhrough the machine, then turn the unit upside down over a sink (making sure it's unplugged first, and always keeping the fill hole down at all times) to let it drain out all the way. Then before you plug it back in, pour water through the machine until water comes out the sprayhead. Then plug it in, let it heat up, pour 2 pots of water through the machine & see if it heats up properly. If this doesn't cure your problem, your unit may need to be completely dismantled to de-scale the tank & thermostat probe.
Jan 20, 2009 | Bunn GR10 Coffee Maker
Coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Bunn BT10B Coffee Maker Logo
43 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
