Question about Sony PS-LX250H Turntable
When plugged in to amp and eq switch on or off no volume through amp.turn amp full up and very low volume.cd ant tuner fine.just turntablethis is the ps-lx250h
  • 396 Answers
Do you have a phonograph input on your amp? If not you may have to purchase pre amp. What type of cartridge do you have installed on the turntable? Do you have a moving coil or moving magnet cartridge? If you have a moving coil your amp needs to have an input for a moving coil cartridge or you must use a pre amp.
Posted on Jul 20, 2010
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Hello i need help please..... I have a Technics SU-Z550 and SH-8055 Graphic Equalizer My amp has lost power... lots.! its working one channel louder than the other but the one which is louder still has...
If the same channel is dead on the EQ as is dead on the amp there may be a correlation.
Let's break this into its two parts.
1) SU-Z550: You don't say WHAT source(s) you tried to use on the CD/AUX, TUner and PHONO inputs. The external device itself could be the source of the low volume. Try swapping the Left and Right cables to see if it follows the source channel or stays with the amplifier channel.
Check the controls on the amp to make sure you understand each one's effect on the sound.
"PHONO" is literal and exclusively FOR A TURNTABLE - NOTHING ELSE - EVER.
2) SH-8055: Equalizers don't 'boost' sound, they modify its levels at various frequencies. To do that they should be connected into a Tape loop on your amp. OUTs go to IN's. Then you select the Tape Loop on the amp and that inserts the EQ into the signal path of whatever source you're listening to. It's actions are BEFORE any other amplifier controls such as volume, tone and balance. The EQ itself also has a Tape Loop to replace the one it occupies. Make sure it is not enabled unless you have a Tape Deck on it to use. Choose "SOURCE". The blue LED display is to show you frequencies are present in the program material.
Set all of its lighted band controls at midpoint prior to declaring it defective. EQ is like any spice - a little is good, a lot ruins the recipe.
Mar 21, 2011 | Technics Audio Players & Recorders
I have a technics ST-X933L tuner as part of a separates system and the volume on the amplifier has to be turned up to almost full volume to be heard. All other inputs are playing at the expected volume for...
You can answer the question by jacking the tuner's outputs into any other Line Level input on your amp/receiver. If it's still low, the tuner is at fault.
BTW: NEVER use full volume as a test unless you intend to blow up your speakers.
Mar 05, 2011 | Audio Players & Recorders
I think I have my cables run improperly/no eq when playing tuner
You could tell us how the tuner, cd and eq are connected for a start. I suspect a Tape Monitor or Source/Tape switch is involved, either in the EQ itself or on a receiver if you have one.
Then you could start isolating for bad connections and cables by swapping the (separate???) tuner into wherever the CD is connected.
Jul 16, 2010 | AudioSource EQ200 Home Equalizer
How do I connect my JVC equalizer to my stero system
I imagine Tape 2 has a corresponding switch on the front panel of the receiver to monitor it.
The rear panel Tape 2 conenctor will look something like Record (Out) / Play (In). Similarly, on the EQ will be an RCA pair of connectors something like Preamp In / Amp Out.
Run a pair from the Ins of one device to the Outs of the other. Select Tape 2 on the receiver to hear the effects of its actions.
The EQ will probably have a switch that selects monitoring the Line (signal from the receiver) or Tape (attached to the EQ). The EQ will have its own Tape 1 (maybe 2) for connection of Tape Deck(s) or other processor(s). On its front panel will be controls to monitor it (them) and for placing the EQ logically in front of (Record) or behind (Playback) those devices.
Word of caution: until you have this all connected exactly right and are comfortable with how it interacts with your recever, ALWAY TURN YOUR VOLUME DOWN TO A SAFE LOW SETTING, prior to selecting or deselecting any Tape Monitor. Whatever you do, don't run the volume up in frustration because you can't hear the desired program and then suddenly flip the right switch only to blow up your speakers from the sudden appearance of LOUD music.
Jan 20, 2010 | Audio Players & Recorders
I have a Amp,CD player,Tuner,and DVD player. no a tape deck.how can i conect all, with out a tape deck through eqeualizer.
You can connect the EQ on the tape in/output of your amplifier. Tape out (or monitor out) to the input of the EQ and tape in to the output of the EQ.
Listen to the tuner and than switch to the tape input, the tuner input will be still active. But in the tape "mode" your EQ will be active too.
Regards,
Gerard
Jan 10, 2010 | Yamaha EQ-70 Home Equalizer
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Sony PS-LX250H Turntable Logo
427 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
