Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 '' 19.5hp lawn tractor gear shift will not engage. Engine and blades work fine but cannot put tractor in gear.
    Sergeant:
  • 200 Answers
The belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Testimonial: "Good to know. Thanks for the quick reply."
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Ok i have a problem with lt 1000 craftsman lawnmower. the tractor starts up runs great just when you put in gear or try to put blades in motion it shuts down can someone plz help
check for a safety switch near your shift handle for the gears . most have a kill switch for when your mowing and go to drive in reverse with the blades on . when you go to do this it puts the shift handle against a metal switch that closes a normally open circut that ends up grounding the coil to kill the engine .. easiest thing to try and dont cost to try . is to unplug this ( temporary ) my mtds have 2 wires not sure if craftsman has these or not . but if so just unplug it and it should work and run like normal if this is what the issue is .
Nov 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi , i have a craftsman 16hp model 944 602261 the engine run fine and the tractor work fine on each speed but when i engage the blade the engine dies the blade are free any idees ???
When you engage the blades you are putting an extra load on the engine. This mean it needs more fuel and more air to keep running.
I suggest cleaning or replacing the air filter, it may be clogged just enough to let the engine run with little load, but when you put a load it cant get enough air. This happened with my string trimmer this summer.
If that doesn't fix it then I recommend pulling off the carburetor (between the air filter box and the engine), taking it apart and cleaning it with carburetor cleaner. If its getting enough air at full load then it isn't getting enough fuel, there could be a partial blockage of the jets inside the carburetor.
Jun 10, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
It starts but as soon as you turn on the blade or put it in gear it kills the engine
Keep your clutch pedal depressed when you engage blade3 or put in gear.Good Luck!
Aug 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine runs -blade engages and throws grass, won't drive
craftsman 46in kohler22.5hp motor runs great ,cuts great, but wont pull uphill.
Sep 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
702 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
