Question about Kodak ESP 5 Printer
Kodak ESP5 all in one printer. paper guide has gone to far to the right and I can't get it back Help!
  • junejones669 Jul 20, 2010
    the paper guide (the grey plastic thing in the bottom of the printer) has been pushed too far over to the right ( I was trying to photocopy on to a narrow piece of paper) now I carn't get it to go back.
    got it back ok but it dosn't seem to sit flat, the right hand side is raised up a bit?
  • Kodak Master
  • 4,737 Answers
I can't figure out how did you make it get too far to the right. Well, you can easily pull it back, if there's obstruction, then use a screwdriver as a lever, trust it inside the bottom of the paper guide with your left hand, and adjust it with your right hand. Try slowly so that you may not break it. Push left- right, push-pull in and out while you drag it to the right. Don't forget to hold it from the clip, in fact, it easily moves when you drag it from the clip. When you hold it, it'll loosen the grip to the base, and when you release it, it tightens the grip. Hold it and drag it, if there's no physical or mechanical damage, you'll be able to fix it.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Jul 20, 2010
  • 4,889 Answers
From the application you are printing, click on file->page setup or print properties to adjust the margin properties. That should do the trick.
Printer paper is jammed. Is there a release?
is there a... what? you didnt provide additional information, and you left the question unfinished. is there a way to remove the paper? is there a solution? yes. the paper can be removed. but i dont have enough information.
Product summary The good: Improved photo quality over previous model; attractive design; large 3-inch LCD screen; easy-to-use Home Center software.
The bad: Poor quality build with several mechanical errors; average print speed; graphics quality still lacks definition.
The bottom line: The Kodak ESP5 is an attractive full color all-in-one printer, scanner, and copier, and casual photo enthusiasts will be happy with the watered-down editing software, but hard-core users should look elsewhere for a multifunction printer. The ESP5 is too expensive and suffers from too many mechanical deficiencies for us to give it our CNET stamp of approval.
you will continue to have these paper jams.
Jun 04, 2010 | Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
Kodak ESP5, duplex, only prints first side
You can try ressting the settingson the printer By going to Menu -> Printer settings -> Reset All settings and hit Ok.
If the issue persists, try upgrading the printer software and the firmware. The link for the upgrade is kodak.com/go/esp5downloads
Oct 07, 2009 | Office Equipment & Supplies
I have kodak esp5 printer.it's not printing. it keeps saying printer error failed to detect paper edge. what should i do?
first you insure that paper tray is fix properly then clean the paper sensor & refix the catridge.
Sep 07, 2009 | Kodak ESP 5 Printer
ESP5 printer not printing photo's on glossy paper
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 18, 2009 | Office Equipment & Supplies
Hello. I took the back off my Kodak esp5 to clear pieces of paper that jammed. Now I don't see a way to replace the back.
go to www.kodak.com/go/manuals and download the manual. it will guide you on how to solve the issue. anyways the bottom side of the door needs to get in first and the you need to push it from up and you are ready to go.you will hear a click sound.
Apr 20, 2009 | Kodak ESP 5 Printer
Is it possible to print 5x7's with the kodak esp5
Print from your computer :
open the picture you want to print
go to :
File
Print
Properties
another windows will pop up and under general you will see different print size and you can chose there the different paper size and print size.
Apr 11, 2009 | Kodak ESP 5 Printer
Kodak ESP5 Printer - actual paper jam
you can pull it out from front and if you don't want pul it out from front just open up the cover of roller then take off the paper.
you are done
Good luck
Feb 09, 2009 | Office Equipment & Supplies
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
