Question about Electronics - Others
Water pump connection for Avondale caravan
We have lost our water pump connection for 1999 Avondale Rialto 550/4. Tried getting a replacement but it seems these are no longer made ant that we need to get a new housing etc. Can you confirm what we can do please and what parts we should buy.
aborcass
  • 2651 Answers
SOURCE: kitchenaid dishwasher kudp01 pump problem
holding the center nut for lack of better word and unscrewing the wash arm, the next piece will require turning clockwise while pulling up on the plastic lock tab holding to up spout for water supply, gives you access ot 5 torx screws, after that theres 2 more torx screws giving you access to the chopper/ impeller area, thats as far as youll be able to go.
Posted on Mar 18, 2008
SOURCE: Cannot receive inputs other than Ant A and B
If ANyone need a solution for this stby
Posted on Aug 31, 2008
brainyass
  • 242 Answers
SOURCE: 2002 chryler sebring is leaking anti freeze
It depends on where the leak is coming from. If the water pump is leaking, it has a hole on the bottom of it. You will see a trail of dried anti freeze coming from the bottom of it, indicating a bad water pump. It's best to dry everything off, crank it up and let it come to operating temp and check for where the leak is coming from. It may just be an old hose or loose clamp.
Posted on Nov 20, 2008
  • 15 Answers
SOURCE: Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Posted on Feb 04, 2009
  • 700 Answers
SOURCE: TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Posted on Apr 11, 2009
Where do i get a replacement canopy for my 10x10 avondale gazebo?
www.ezreplacement.com/rplc-roof-bracket-avondale-gazebo.html
Lots of places. Their are also tent and awning companies that will make you up one. One on Gravois Street in St. Louis,MO. for example.
Jun 16, 2014 | Astonica Avondale 10x10 Gazebo
My 1999 dodge caravan was smoking from under the right side of the hood
if you lost antifreeze its the water pump
if it smelled rely strange and funky you could have a brake caliper binding causing brake pads to stay applied need more info to ferther help
Feb 26, 2014 | 1999 Dodge Caravan
Mayfly avondale caravan wiring diagram
i need the wiring diagram for under the seat where the emersion is for an avondale mayfly
Jan 29, 2012 | Cars & Trucks
Replacing water pump/bolts
SOME PART STORES OFFER A WATER PUMP BOLT KIT. BUT IF NOT CALL YOUR LOCAL DODGE DEALER PARTS DEPT. AND GET THE SPEC'S ON WHAT SIZE BOLTS IT USES
Oct 27, 2011 | 1994 Dodge Caravan
WATER PUMP REPLACEMENT QUOTE
I don't have a labor manual in front of me right now but i can tell you that it's not cheap. The water pump is driven by the timing chain which requires a bit of labor to get to. If i recall correctly it's at least a 3 hour job so depending on your local labor rate it should be around $350-550.
Sep 04, 2010 | 1999 Nissan Maxima
Delonghi rialto eam4500: Lost Hot Water Spout. Where to get one?
I had the same problem!! I was able to find one on Amazon:
http://www.amazon.com/DeLonghi-5532124900-HOT-WATER-SPOUT/dp/B002EKFX06
It works on 4500 as well as a couple of other models :)
Jul 25, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Remove and replace a (in-tank) electric fuel pump for a 1999 dodge grand caravan...3.8 litre
To replace the fuel pump you must remove the fuel tank disconnect hoses connecting the tank, disconnect the battery and remove all the fuel to facilitate the assembly you ... Thanks
Feb 26, 2010 | 1999 Dodge Grand Caravan
Getting the serpentine belt back on
Replace the defective tensioner.
Mar 14, 2009 | 1999 Dodge Grand Caravan
Electronics - Others Logo
102 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
