Question about Linksys Wireless-G WRT54G Router
Im from d Philippines, im currently seting up my Linksys wireless-G WRT54G Router, after entering the password it says "Setting up router" then the next message would be "checking internet connections" and here comes the problem, another message would come out and says something like this "The router couldnt connect to the internet try switching the MODEM/DSL cable on and off then try again" i keep on trying this procedure but no progress:(( please someone help me with my problem, by the way you can email me at rmaquiso@yahoo.com thanks!
  • 550 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Jul 21, 2010
Setting password, lock
Connect the computer to the router with the Ethernet cable.
Open Internet browser and in the address bar type 192.168.1.1.
Log in to the router.
Go to router settings.
Change the wireless network name SSID.
Change the security mode to WPA. Enter the password. Save the settings.
Try to connect to the new network.
Read more about Wireless network security
Jun 22, 2012 | Linksys Wireless-G WRT54G Router
User and password after hard reset
When you do a hard reset it will reset you router. what you need to do is login to your router using the factor seting and reconfigure the router again
Feb 16, 2012 | Linksys Wireless-G WRT54G Router
How can i recover my wifi password
You must log into the router using the routers internal ip address. Open your default browser (eg: internet explorer or google chrome) and enter 192.168.1.1 into the address bar, press enter. You will be prompted to provide a username and password, use admin for both, press enter and the Linksys GUI will pop up. You will need to navigate to the wireless settings tab and either write down your current password or change it. Make certain that you save all current settings before exiting the GUI.
Sep 29, 2011 | Linksys Wireless-G WRT54G Router
Im trying to find my password for my router but i cant.
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router and create a good wireless network security.
Through the Web Administration PagesThe second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router and maintain your wireless network security.
SummaryThis post has provided two methods you can use to reset your Linksys WRT54G Wireless-G router. If you are having problems with your router, try resetting the router to the factory defaults, and then make the changes again and see if the router starts working again.
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
I have a linksys wireless-g and the internet wont work. like the green light next to the word link is flashing green. Im not sure what to do
is your internet provider gives you a static IP? if yes change the setting of your router to static and encode the static ip the provider gave you..because the default setting of all routers is obtain..to go to the setting of your router..just connect your computer to yopur router..and on the internet explore type the gateway of your router..usually its 192.168.1.1..user name:admin password:admin..hope its helps..
Jul 26, 2011 | Linksys Wireless-G WRT54G Router
How do set a password to secure my connection
I have found this website detailing the steps necessary to setting up your Linksys Wireless-G WRT54G Router with a password. You can skip steps 7 - 8, unless you know about MAC address filtering, and wish to implement it (MAC address filtering allows only the computers you specify by their MAC address to connect to your network, eliminating outside computers from connecting to it).
Here is the link --> Set Up Linksys Wireless-G WRT54G Router
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
How can I change the password on my Linksys router (WRT54G)?
On a computer connected to the linksys now.
Click the link below
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is your password.. If it looks like **************
You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now found out, or reset your wireless password.
***Note*** If you changed the password.. The current computer will also have to reconnect to the network, and enter the new password.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Nov 22, 2010 | Linksys Wireless-G WRT54G Router
I lost the security key to my wireless internet how could i disable my security
This article will guide you on how to change the password of your Linksys router.
NOTE: The default password of your router is "admin" and no User name. It is recommended to change the Password for security purposes. If you forgot your Password, press and hold the reset button at the back your router. To learn how to reset the Password of your router, click here.
Changing the Router's Password
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click on the Administration tab.
Step 3:
Enter the new password in the Password field and Re-enter to confirm.
NOTE: The image may vary depending on the model number of the Linksys device.
NOTE
: If the window on your router's web-based setup page looks different, click here.
Step 4:
Click 3695-017.png.
NOTE: The next time you log in to the router's web-based setup page, make sure to enter the new password.
Related Articles:
Setting-Up WEP, WPA or WPA2 Wireless Security on a Router
Checking the Wireless Settings on a Linksys Router
Downloading at Linksys by Cisco Support Site
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
How do i set up a password for the router?
access following link
http://192.168.1.1
or
http://192.168.0.1
then type user name as "admin" and password as "admin" or blank or "password"
then set your internet as WEP then enter wep 128 bit encryption key like number thensave setings wep encryption key is your password.
Jul 17, 2009 | Linksys Wireless-G WRT54G Router
Change password, linksys router, wrt54gs
are you referring to the wireless password like WEP or WPA key? if yes,you need to connect your laptop first to your router with a cable,go to 192.168.1.1, then enter,username should be blank ,password is admin, theres a setting there for wireless security
Oct 10, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
