Question about Karcher Plumbing
I have a new construction in which I have a deep water well pump (560 feet well) that pumps into a 1500 gallon cistern. I then have a second pump in the cistern that feed into the house. I now need a pressure switch that controls these pumps and a well pressure tank. Can up help with the setup? I don't know the name of either pump so I just picked a brand.
  • Karcher Master
  • 901 Answers
A pressure switch is a pressure switch. Any of them will work unless you have something really odd. If the pumps are just normal pumps it'll be OK. Plumb and wire them according to the diagrams.
Posted on Oct 07, 2017
  • Karcher Master
  • 3,411 Answers
Look on u tube I found some system sets ups for my house the video's where very help full .
Posted on Oct 04, 2017
Healeyman
  • 1198 Answers
SOURCE: shallow well pump made by wayne well is 22 feet deep pump runs no
Inspect the jet thru the suction pipe or the removable plug if the pipe isn't inline with the center of the impeller. The jet is very small, and easy to get something stuck in there. Then prime and leave the pressure pipe closest to the outlet slightly loose to let air out. Once you get good pressure you can tighten the pipe. Sometimes you have to prime more than once to get all the air out of the well pipe.
Posted on Apr 05, 2009
Healeyman
  • 1198 Answers
SOURCE: pump 30/50lbs pumps up to 50 shuts off pressure drops to 32lbs
Look for a place in the pipe from the pump to the house where an air pocket could form. That will fool the pump.
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 1114 Answers
SOURCE: Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
Posted on Jul 08, 2009
woobie dog
  • 1273 Answers
SOURCE: Well pump not shutting off and tank never reaching full pressure
50 years old isn't bad..... but technology has changed a bit. I do have a few ideas. I'll list out several problems/solutions, and you'll have to pick and choose, depending on your particular circumstances. It will be a long read, but I would suggest that you read to the end before picking a course of action. Hopefully, others will offer advice as well.
Make sure that you have a working pressure gauge. I only say this as all of your (and my) assumptions have and will be made off of the gauge. It's critical. OK, with a working pressure gauge....Are we seeing the same pressure? If the pressure is actually higher, say, in the range that you are regulating for, or higher, the pressure switch is suspect and should be investigated/replaced.
When you shut off the pump, does the water pressure fall off? If it does, this might indicate a leak either internally (well/pump) or externally (faucet, etc.). Locate the regulator on the side of the pump. With the pump running (and a good pressure gauge), turn the regulator adjustment several flats, rembering your original position. This is best done with the pump at max pressure. Operate it in both directions, say four flats one direction, back the same to the original position, then 4 in the opposite direction, and back to the original position. Note the pressure on the gauge each time you make an adjustment. If any improvements are noted, work with it.
The most common problem with pumps not putting out enough water usually isn't the pump, but the well itself. Most wells have a foot valve and jet valve assembly. The foot valve has sealing rings on them known as leathers (although these can be made out of other materials). If the well is shallow, say 20 feet or less, the pump will normally pick up water without too much difficulty, even if it won't maintain pressure at the tank. Not knowing the depth of your well and the age of your equipment makes it a little harder to diagnose. Slippage within the pump, allowing some of the water to spill back, is a possibility, but you would expect the pump case to heat up over time, and this doesn't sound like the case. My guess is that you have some leak-by in either the jet assembly or the leathers, allowing some of the water to leak back to the well. The foot valve would keep the water pressure from dropping to zero. I'd trip the breaker to the pump motor and break the well head away from the pump (leaving the cast iron piece on the inner pipe). You should have a triangular piece around the outer well casing. Loosen the three bolts, then remove the two bolts that hold the pump to the well head. Gently separate the two, and set your pump off to the side. The aim with "gently" is to avoid tearing the gasket. (If it does tear, you can purchase gasket material and hammer one out, if replacement gaskets aren't readily available). Once the pump is removed, you can remove the inner casing to which your jet and foot valves are attached. Careful when removing it,though. You do not want the inner casing to unscrew from the well head and fall down the well. If there is a lot of sediment in the well, it will be more difficult to remove the inner casing, as the leathers press against the outer casing making the seal. I have always put several gallons of bleach down the well, although recently, a neighbor had muratic acid put down his well. This is dangerous, however, and only trained and skilled personnel should attempt. I let the bleach sit for several hours, allowing time for the bleach to soften the leathers. Once done, extract the inner casing, pulling the well head, inner casing, jet valve and foot valve as a unit. You'll have to pull it in a big arc and lay it out slowly as you go. More hands are better for this task. You may need to get creative in supporting the line it it's PVC. Once extracted, visually inspect the lower components. I recently saw one with a hole eaten in the top of the jet valve, producing similar results to your issue, but worse. Anyway, if this is where you are at, I would, at the very least, replace the leathers. And, I'd double them. Truth is, when I go to that much effort, I replace everything at the bottom of the well, foot valve, jet valve, leathers....
We havent hit on the tank yet. Older systems had an air injection system where a shot of air was injected every time the pump cycled. If no air went into the tank, the tank would become "waterlogged" over time, and would cycle constantly. This system was prone to failure. The remedy for this was to drain the tank, and start over, and to replace the air injection system. This usually called for the pump to have to be reprimed as well, at least at my house... Newer tanks have bladders in them with a pressure set on them to provide the same air cushion that the older systems provided. The air pressure on mine is set to 28# via a schraeder (bicycle tube) valve at the top of the tank. Check yours if so equipped.
Well, that's about it for now. Make your checks and please let me know what you turn up. I'll check back.
Best regards and good luck,
--W/D--
Posted on Jul 19, 2009
How many gallons does a 15' round pool 35 deep have
Basic school maths Pi R Squared, but are you sure this pool is 35 FEET deep?
Pi, (3.142) x radius squared
the radius is half the diameter x itself, x depth. and then
There are 7.48 gallons in cubic foot
Your pool diameter is 15' diameter, so 7.5 radius. 7.5 x 7.5 is 56.25. Multiply that by the depth. Multiply that answer by 7.48 gallons
Area of Circle
May 25, 2016 | Pool & Spa
I have a utilitech 1 hr convertible jet pump. My well is 58 feet. My foot valve is at 68 feet. My pump is primed. But it still won't pump water. And it us set up for deep well. Any suggestions?
I think you mean your well is 68 feet and your foot valve is at 58 feet. To properly prime a deep well jet system you must completely fill not only the pump but the entire casing also. This should take about 5 gallons of water. If you are not using anywhere near that much water to prime it may be the well casing is air locked which means the air in the well has no place to go and won't allow water in if there is a plug on top of the well adapter remove it and then try to prime system. Another method is to run the pump while priming to help break the airlock. Hope this helps.
Bob
Jul 26, 2015 | Jet Plumbing
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
How many gallons of water in 3172 cubic feet of water?
There are 7 1/2 gallons of water in a cubic foot.
3172 x 7.5 = 23,790
To calculate how much water in a swimming pool, in 'US Feet':
Length x Width = Surface Feet
Surface Feet x Average Depth = Cubic Feet
Cubic Feet x 7.5 = Total Gallons
Mar 07, 2015 | Pool & Spa
I have a submersible Gould pump in a well. Recently air is getting into my system and coming out as irregular spurts. I replaced the water storage tank and the check valve, and the problem persists
Sounds like pump is not set deep enough and getting air. If the pump is as deep as it can go you may have to have to screen in the well changed or cleaned with acid pellets.
Dec 28, 2014 | Plumbing
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
Can a Grundfos pump fail, letting water out of a cistern?
Glad you got it fixed. Hope you didn't lose all your water in the process, we've been that way at times with our little system (can only afford 450 gal of storage with 650 gal transporter, no well).
Watch those strains on the pipes and make sure any further changes have good one way flow valves for this type system, expense doesn't look so bad when the alternative is being waterless!
Sep 01, 2012 | Grundfos Pumps Grundfos sqflex submersible...
How many gallons of water the intex 15x36 pool holds?
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Jul 10, 2011 | Intex Easy Set Pool 15x36
Grundfos pump leaking?
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
Aug 01, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Jul 26, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Plumbing Logo
530 people viewed this question
Top Karcher Plumbing Experts
Paul Carew
obsteiner
JOHN BROWN
Are you a Karcher Plumbing Expert? Answer questions, earn points and help others
