Question about DeLonghi Dehumidifiers
Whats the size of the rubber bung / stopper. I have the DEM 100.
I just bought a second hand DEM 10 DEHUMIDIFIER. After starting it up (on every setting) the motor cuts out after a few minutes. All filters are clean. Please help. Kind regards Scott
assuming you have ck'd the water collection bucket full switch for proper seating , im sorry to say that short cycling on compressors are a sure sign of low gas pressure , and no its not easy to add more
Nov 20, 2016 | Dehumidifiers
I have just bought a secondhand challenge 414/0038 and I cant find where you empty the water when using dehumidifier?? As you can guess I didn`t get any instructions with it
There is a rubber bung on the bottom of the back of the unit. You remove this bung and water will drain out.
However you should read the manual because most of the humidity is supposed to come out of the exhaust with the hot air. I'm not sure how this works but it's in the manual
Please find the manual you need here:
http://www.stator.me.uk/414-0021.pdf
This covers 414/0038 and 414/0021 Air Conditioning units by Challenge
May 24, 2015 | Dehumidifiers
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
My delonghi airadry slim is not draining through the hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Keep it in case you want to go back to the bucket.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jul 29, 2017 | Dehumidifiers
What is the drain size to run in copper for Zenith ZD300 dehumidifier. The inspector will not let us use a garden hose for drain as per you instructions. Fire hazard, we have to run a copper drain. What...
Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
Sep 19, 2011 | Whirlpool Dehumidifiers
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over....
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Sep 28, 2009 | DeLonghi Dehumidifiers
Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
May 03, 2009 | Dehumidifiers
Need to replace the overflow stopper gadget.
CONTACT YOUR LOCAL MAYTAG REPAIRMAN. THEY WILL PROBABLY NOT ONLY SELL YOU THE PART BUT WILL TELL YOU HOW TO INSTALL IT. THEY WILL ALSO BE GLAD TO REPAIR IT FOR YOU AT A NOMINAL FEE. GOOD LUCK.....JLR4
May 31, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
74 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
