Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven is locked I can not get it open
I am babysitting while daughter-in-law is in Kuwait. Somehow me or the kids have the locked button on and the oven will not open and I can't get it fixed.
    Problem Solver:
  • 9 Answers
You should be able to hold down the "Clear/Off" button for ~ 5 seconds and it should unlock. I had to do this a couple of times to get mine to work correctly.
Posted on Jul 25, 2010
I don't know the model # but its a kenmore oven and my daughter left her finger on the stop button too long and so the oven door automatically locked us out. I can't find the book for it
According to the eHow website,
"press and hold the stop/clear button for 3 seconds to unlock the door."
(it's the same to lock the door in the first place.)
According to the Just Answer website, either press and hold the stop/clear button for 3 seconds or 5 seconds, (A beep will sound. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked and the lock icon light has cleared.) or you have to press the button 3 times quickly.
Sep 25, 2012 | Kenmore Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
I was baking dinner and the kids walked by and looked oven door. Now i can't get it to open. Its a magic chef/ self cleaning oven
Need to know the exact model to be sure, but usually there is a button that says "lock" or has a padlock icon that you press and hold for a minute or so to lock and unlock.
Also, if they started a cleaning cycle, that will lock the door, too.
Apr 21, 2011 | Ovens
My daughter canceled the self clean on my Fridgedare Oven Professional series gas stove oven door and now I can't open the lock to use the oven again. How do I reset it. Thanks Erika
Disconnect the power supply cord for several minutes. It should clear the memory and restore it to factory default settings. Also check for a reset button.
Apr 15, 2011 | Ovens
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Series Oven Locked
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Feb 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
89 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
