Carrier A/C unit not cooling..but freezing refrigerant tube.
I have a Carrier furnace and A/C unit. Model # CD5BXA06000AAAA. A few days ago I noticed a puddle of water on the floor at the base of the A/C unit. The refrigerant tube was condensing and freezing over (both inside and outside). When the unit is off, I hear what I think is large ice blocks dropping inside the unit. Set on 'AUTO' it no longer turns on and off automatically. Water does drip from the condensate drainpipe, although i dont think as much since i have noticed this problem. Cold air is coming from vents but not cooling the house (3200 sq ft). Any suggestions?
  • 21 Answers
If the fan isnt running or you dont get enough return air (on the furnace) the coil will freeze up or if you have it set too low it will freeze up overnight, make sure your filters are clean, and that you dont have any return vents (air sucking in) covered with rugs and whatnot. If you have animals, the coil (on top of the furnace) could be clogged with hair, even though you change your filters it still gets clogged with hair and must be cleaned. if your coil was froze up you need to make sure it is completely thawed out, run the fan in the on setting with the a/c off until you dont see or hear any more water then turn it on again. and finially make sure when the furnace goes off (thermostat clicks and is satisfied) the outdoor condenser goes off as well the contactor could have been stuck in the on position. if you cant fix it call someone who can when your coil freezez up it can cause slugging in your compressor (liquid entering the compressor) which will destroy it !!!!!!!!!!!
Posted on Jul 21, 2010
Dometic fridge NDR1292 in RV has started to make a hissing noise at least once a day for about 5 seconds. Also, cooling fins are icing up very quickly, every few days. Does something need replacing?
NDR 1292 amish style cooling coil replacement - YouTube
? 8:13
www.youtube.com/watch?v=Ru6lFABsqnk
Oct 13, 2012 - Uploaded by taintedcrimsonwings
Step by Step instructions for replacing a Dometic NDR1292cooling unit. ... RV Refrigerator Cooling Unit Replacement Part #2 Installing The ...
Sep 27, 2015 | Dometic NDR 1292 Refrigerator
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
The outside unit of my Carrier Air Conditioner/Model # 38TG030300 is freezing up the line going to the unit inside.
Is it freezing up at a drier or just a section of tubing? More info would be good. If the line is frosting up all the way back from the indoor to the out door coil, and I guess that we are talking about the suction line, the larger of the two. My guess it either the stat. is set to low below 72 degrees and or the indoor coil is dirty or the filter is. Clean the indoor coil be careful to not get water else where such as into the furnace take appropriate steps to prevent it. All AC units have to have 400 cfm of air flow for each ton of cooling if the do not have this they will freeze up, vents closed off will do the same as a dirty coil.
Jul 02, 2011 | Heating & Cooling
Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
Apr 20, 2011 | Ruud Matching Split Air Conditioner
I have Carrier Heat pump model # 25HBA. It was installed 3 years ago. I have had problems with it several times. This time, it is freezing up on the outside unit. My electric bills have sky rocketed. What...
The cooling coils are freezing because the gas (coolant) in the system may need replenishing or a small leak in the system. Something you can check yourself, is whether or not the foam insulation on the refrigerant tubing coming out of the unit is still intact. If not, that tubing is probably freezing too.
The other possibilities will need to be check by a qualified service technician.
Feb 10, 2011 | Carrier Heating & Cooling
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
